Author Topic: Black PBT blanks?  (Read 3707 times)
Offline devoi
Black PBT blanks?
« on: Thu, 06 October 2016, 20:56:51 »
I've been a bit disappointed in trying to find these caps. For quite a while now I have been looking for Cherry profile blank thick PBT blanks.
At first I tried buying from geekkeys, which went fine, except for the fact that I received gray-colored caps:http://i.imgur.com/mhxzQ1b.jpg
I've also made a small album of the keys I received, just to make sure that I'm not just insane: http://imgur.com/a/2qeN7
If you notice, the keys in the bottom picture are black, except for the one spacebar, which matches the rest of the caps in the set, which I find odd. This says to me that the gray I received isn't just what they use for black, but that there's a difference between these gray caps and their black caps.
Unfortunately, their service hasn't been too keen on helping me somewhat quickly (I'm probably just too impatient, but it's been a couple weeks), so I decided to try a different brand.
After buying enjoypbt black blanks and receiving caps in the same gray color, I returned them.
I believe that taobao and maxkeyboards have sets, but they're OEM profile, rather than the Cherry profile that I'm trying to find.
Does anyone know of a working source of this type of caps?
Offline nickheller
  • Cherry ML life
    • hickneller.com
Re: Black PBT blanks?
« Reply #1 on: Thu, 06 October 2016, 20:58:29 »
I have these, seem pretty black to me
« Reply #2 on: Thu, 06 October 2016, 21:01:28 »
Finding true "black" PBT keycaps is hard.
I speculate that the reason for this is because PBT isn't as smooth as ABS, so color doesn't come across as well. It's a lot harder to get that "true" black in a PBT keycap.
If you're set on PBT, you probably won't get a deep black. The best I've seen are IMSTO black PBT caps.
You could also do research into POM keycaps, or settle for the dark grey that's so common.
Offline devoi
« Reply #3 on: Thu, 06 October 2016, 21:06:12 »
Those were the ones that I bought that turned out to be gray   :(
Damn. I've seen a few people with pretty genuine-looking deep black pbt caps. Kinda saddening. I also find it kinda weird that there's a lot of easily-accessible OEM profile caps that match the description, but not the exact same set in cherry profile  :(
« Last Edit: Thu, 06 October 2016, 21:19:15 by devoi »
Offline Gatix
  • #!/bin/sh
  • console.log
« Reply #4 on: Thu, 06 October 2016, 21:46:59 »
Did you get the $60 black blank or the $40 dark gray from Geekkeys?
Offline devoi
« Reply #5 on: Thu, 06 October 2016, 21:55:17 »
http://www.geekkeys.com/geekkeys-black-blank-thick-pbt-full-keyset/
These were the ones I bought.
