Author Topic: Well look what we have here.  (Read 2806 times)
Offline Hanjin
« on: Sun, 17 January 2010, 16:46:00 »
Just received this from the post this morning brand spanking new sealed in box along with cover:
Not bad for $15 AUD.
| Leopold fc200r | Chicony KB-7001 |
Offline spolia optima
« Reply #1 on: Sun, 17 January 2010, 18:13:36 »
That's one of those Chiconies, right?
I honestly love the design. It looks broken, like someone actually ripped a regular keyboard in half (paging ricercar to triage!).
Most ergos avoid that distinction with centered arrow keys, a fancy bezel, or offset numpad... Like they're trying to hide it, or something. F**k postmodern design sensibility, just give me rectangle.... Then break it.
Oh wait, i think breaking a rectangle is actually the definition of pomo. S**t.
« Last Edit: Sun, 17 January 2010, 18:17:46 by spolia optima »
keyboards!
Offline Hanjin
« Reply #2 on: Thu, 21 January 2010, 01:28:20 »
Anyone know what other key caps I might be able to fit this board?
Screwed up a few keys trying to rit dye them.
« Last Edit: Thu, 21 January 2010, 01:31:35 by Hanjin »
Offline ricercar
  • mostly abides
« Reply #3 on: Thu, 21 January 2010, 01:33:32 »
Northgate Omnikey boards use ALPS white or blue.
You're in good company. Did you use a thermometer? What temperature was the dye?
Offline Hanjin
« Reply #4 on: Thu, 21 January 2010, 01:41:52 »
Quote from: ricercar;152577
Northgate Omnikey
I left the keys in for too long and the keys hit the bottom of the pot while i was stirring.
Lesson learnt the hard way.
Offline Hanjin
« Reply #5 on: Thu, 21 January 2010, 04:56:58 »
Ouch that is pretty much what happened.
Offline Hanjin
« Reply #6 on: Thu, 21 January 2010, 05:13:51 »
Thanks for the help.
