Author Topic: logitech g610 layout  (Read 8656 times)
Offline espgodson
« on: Tue, 11 October 2016, 08:27:37 »
alright so i've been using a ducky but i want some multimedia controls while i stream/play game well i used AHK for the top right calc/mail etc buttons but in certain games if i go to pause or change track it tabs me out of game. so i bought a g610 which i later found out doesnt have a standard layout.
i use these keycaps theyre green pbt ducky soo i can use all the keys on the 610 except for caps lock, space bar & alt keys.
i'm fairly certain you can't buy the correct size space bar anywhere so are there any companies out there that do complete custom layouts? i have no idea how this kind of thing works..
if it would be cheaper to buy a new keyboard with a standard layout & dedicated media controls i would love some recommendations. i just dont want any fn+ controls...
apologies for the ramble passing 2 kidney stones and its hellll and i havent slept D;
Offline seville57
Re: logitech g610 layout
« Reply #1 on: Wed, 12 October 2016, 03:12:25 »
I hope you feelin better.
I would buy a new k-board with a standard bottom row and you find lots of keycaps sets that will fit, stay away from corsairs k-boards + some k-boards in the link as they don't have a standard bottom row.
I have the same keycaps set but blank, I'm usin that set on one of my Ducky k-boards.
Here is a bad picture of my blank Ducky Cream/Cheese set. The k-board is a Ducky Shine 3 or 4.
The Ducky Spacebar in the set have the size 1x6.25 (standard Spacebar size) and there are also Spacebars non - standard sizes 6.0 and 6.5.
Here is a link that showin the Keycaps and Spacebars sizes on some k-boards:
http://blog.maxkeyboard.com/dwkb/keycap-compatibility-size-chart/
The second row in the link, Ducky, Das, Deck + some more have a standard bottom row size.
The company in the link makes custom keycaps sets but only ANSI 87 - 104 and ISO 88 - 105 keys sets.
« Last Edit: Wed, 12 October 2016, 05:37:18 by seville57 »
