Author Topic: GON turns all their keyboards Bluetooth-USB combo by a new PCB module  (Read 4896 times)
Offline menuhin
Their new optional PCB module to fit in all their newer generation PCBs, turning a PCB bluetooth-USB combo:
Has any member already ordered?
Source:
http://www.gonskeyboardworks.com/pcbs-and-controllers/119-bluetooth-option-set-for-nerd.html
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline czarek
  • Keep the momentum going!
    • FalbaTech
Re: GON turns all their keyboards Bluetooth-USB combo by a new PCB module
« Reply #1 on: Fri, 14 October 2016, 08:28:11 »
Is that new? I had bought this kit with my Nerd 60% over 2 years ago. It doesn't work with Mac though so please be aware. It does work with iOS, Android and Windows however. Haven't tested with Linux.
Offline menuhin
« Reply #2 on: Fri, 14 October 2016, 08:46:30 »
My bad. I thought it is new because most of their case housing do not fit this kit, and there are PCB (MX-mini) compatible to this kit still in pre-order stage.
How long does the Bluetooth last per charge for your use?
IBM M13 black
HHKB Pro 2 HasuBT
Offline chuckdee
Offline menuhin
IBM M13 black
HHKB Pro 2 HasuBT
Offline captsis
  • Formerly matt2dlg
« Reply #5 on: Sun, 16 October 2016, 06:59:41 »
Are you ****ing kidding me? GON should complete his backlog instead of releasing products. Unbelievable.
Sent from my SM-G920V using Tapatalk
« Reply #6 on: Sun, 16 October 2016, 08:09:02 »
It's not new and it can have problems if you build it yourself (see thread) or if you request Gon build it for you you might see the board in 2018...
All things said this looks like one to avoid.
Offline kawasaki161
« Reply #7 on: Sun, 16 October 2016, 08:48:32 »
Do you really think he will be that fast if he keeps his current pace?
« Reply #8 on: Sun, 16 October 2016, 08:59:06 »
I did say 'might' :))
Offline captsis
  • Formerly matt2dlg
« Reply #9 on: Sat, 17 February 2018, 21:42:08 »
ANY NEWS ITS 2018
Offline xondat
  • i'm not a star
« Reply #10 on: Sat, 17 February 2018, 21:47:12 »
ANY NEWS ITS 2018
NO STILL A SCAMMER
Offline Hyde
  • White Tofu Extraordinaire
« Reply #11 on: Sun, 18 February 2018, 08:25:47 »
ANY NEWS ITS 2018
LOL you actually remember to check back 2 years later, that's some dedication.
« Reply #12 on: Sun, 18 February 2018, 08:33:12 »
ANY NEWS ITS 2018
I said might, 2018 is still young...
I'm still advising anyone who mentions gon as an option against it, much as I wish there was there's nothing else anyone can do.
Offline captsis
  • Formerly matt2dlg
« Reply #13 on: Sun, 18 February 2018, 13:22:45 »
ANY NEWS ITS 2018
I like many others have been burned by GON. Pretty much a meme at this point.
« Reply #14 on: Sun, 18 February 2018, 13:29:15 »
ANY NEWS ITS 2018
NO STILL A SCAMMER
yep pretty much
