Author Topic: RedScarf II Ver. B Backlight?  (Read 1896 times)
Offline 15kuhnr
« on: Sat, 15 October 2016, 19:23:56 »
I have recently purchase the Redscarf II Version B, and after quite a bit of searching I wasn't able to find a good tutorial on layout editing. I am trying to figure out how to make a layout where one of the function keys turns the keyboard backlight on and off. Any tips and advice would be awesome! Thanks
Offline Pwner
  • soon™
Re: RedScarf II Ver. B Backlight?
« Reply #1 on: Sun, 16 October 2016, 04:51:25 »
TKG Chrome App works the best.  You have to make your layout on KLE if you didn't already.  Once you set up your layers, you can set up your function keys.  The dropdown menu will let you set-up your backlight toggle.
I'm not the greatest at explaining, if you need any more help, feel free to shoot me a PM.
Here's a quick example layout:
Function keys were set to the left cluster.  You can then set them to whatever you want.
Offline 15kuhnr
« Reply #2 on: Sun, 16 October 2016, 12:47:23 »
I can not thank you enough! This is exactly what I needed. I'll post pictures when I get all the backlight LEDs soldered in. Thanks again!
