Author Topic: Where can I find this design?  (Read 1931 times)
Offline nrp
« on: Sun, 16 October 2016, 15:35:19 »
Guys,
Is anyone selling this design? (The image is photoshopped).
150578-0
Re: Where can I find this design?
« Reply #1 on: Sun, 16 October 2016, 15:48:42 »
CM Quickfire TK
Offline nrp
« Reply #2 on: Sun, 16 October 2016, 15:54:25 »
CM Quickfire TK
Thanks TacticalStache.
Notice how the number block and cursor keys, page up/down etc, are not the same.
Offline MJL
« Reply #3 on: Sun, 16 October 2016, 18:17:20 »
Not the same but close is the Leopold FC980M. mechanicalkeyboards.com/shop/index.php?l=product_detail&p=2045 (although on your picture it looks like there is some indentation for a key right upper corner....)
« Last Edit: Sun, 16 October 2016, 18:19:59 by MJL »
Offline nrp
« Reply #4 on: Sun, 16 October 2016, 18:28:09 »
This is it! This is exactly what I was looking for. Thank you so much.
« Reply #5 on: Sun, 16 October 2016, 18:58:24 »
Cooler Master has a successor to the QuickFire TK out, called the MasterKeys Pro M.
(The 'M' seems to stand for 'Medium" as the full-size is called "Pro L" and the TKL one is "Pro S".)
The big difference is the keycap sizes on the bottom row: The modifiers on the MasterKeys are now all 1.25u.
The keycap font is also nicer, more regular and not as gamer-y.
Otherwise the keyboards seems to exactly the same to me, but maybe there are updates on the inside.
« Last Edit: Sun, 16 October 2016, 19:06:58 by Findecanor »
