Author Topic: I want to make a GH60 with adafruit Bluefruit mod  (Read 2351 times)
Offline soslhg
« on: Tue, 18 October 2016, 00:24:55 »
plan:
1,GH60
2,BT mod   ----adafruit Bluefruit  mod
3,led   ------ws2812
problem:
1,How to use the core TMK Library?
2,I checked a lot of information.i found a project  https://github.com/bgould/arduino-tmk-keyboard/
 write by C++,   The project is changed protocol PS2 to  Bluefruit EZ-Key HID.
The author changed makefile compile to  ARDUINO IDE .
Code: [Select]
#include "config.h"
#include <KeyboardFirmware.h>
BluefruitHost host;
PS2MatrixCodeset3 matrix;
static uint16_t reset_press_time = 0;
void setup() {
    pinMode(KEY_LED_PIN, INPUT);
    pinMode(PAIR_LED_PIN, INPUT);
    pinMode(PAIR_BUTTON_PIN, OUTPUT);
    pinMode(RESET_BUTTON_PIN, OUTPUT);
    pinMode(DEBUGGING_LED, OUTPUT);
    digitalWrite(PAIR_BUTTON_PIN, LOW);            // write high for 5 seconds to reset pairing
    digitalWrite(RESET_BUTTON_PIN, LOW);           // pull low to reset the bluefruit module
    digitalWrite(OUTPUT_LED_PIN, OUTPUT_LED_OFF);
#if DEBUG_ENABLE
    debug_enable = true;
How can I change it, let it be my plan?
