Author Topic: Protection spray paint for ABS cap (to avoid 'shine' and wear)  (Read 6066 times)
Offline menuhin
« on: Thu, 20 October 2016, 06:48:27 »
There are keyboards in the past and now that I am letting them sit in storage because I don't want to create any wear and shine on their ABS key caps. I'm thinking if I can do anything like an invisible protective spray paint on these ABS caps so that the 'shine' can be avoided and I can rest my mind and start trying these keyboards out more often.
Has it been done before?
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Re: Protection spray paint for ABS cap (to avoid 'shine' and wear)
« Reply #1 on: Thu, 20 October 2016, 06:59:36 »
Just use them and get over it, embrace the shine.
Life shouldn't be this complicated. :P
But of all the coatings I've seen none have been very long lasting and only make things worse.
Offline Data
« Reply #2 on: Thu, 20 October 2016, 07:18:53 »
All coatings wear.  There isn't a clear coat you could put on a key cap that wouldn't wear off and look worse than if you'd just left it natural.
« Reply #3 on: Thu, 20 October 2016, 07:47:40 »
All coatings wear.
+ 1
And the disparity between the more worn ones and less worn ones will be amplified.
- D Trump 2026-10-24
Offline sinusoid
  • fd > ESC
« Reply #4 on: Thu, 20 October 2016, 08:04:05 »
There are a few things you can do, actually.
You can sandblast them with a very fine grit, deskthority thread here: https://deskthority.net/workshop-f7/keycap-sand-blasting-t12946-30.html
Or if you're fixed on coating them, there are some interesting two-part epoxy lacquers designed specifically for abrasion resistance, used for example in marine engineering. You should research, but here is one example: http://www.hempel.com/en/products/hempadur-15590
These should be overkill enough :)
ABS is reactive with solvents, though, so some resins can damage its surface. Make tests, pre-coat with acrylic, etc.
