Author Topic: Worth it? Infinity x GMK 3Run 60% Massdrop  (Read 3863 times)
Offline iLLucionist
  • Topre is Love.
« on: Thu, 20 October 2016, 19:45:25 »
I cannot solder myself (thus far), so I have to rely on others. So I'm considering this:
https://www.massdrop.com/buy/infinity-keyboard-kit
(Sorry, couldn't find non-login link anywhere. ?guest_mode=1 didn't work for me)
Let them solder it for me. I envision this as the pok3r that never came: a true MX Clears HHKB with 100% customizable open firmware.
1) Anybody experience with Massdrop letting do the soldering?
2) Would the metal case (55 dollar) be worth the additional fee?
3) Can I fit a regular PBT MX keyset, considering the standard hhkb-like layout? I'm worrying I get mixed up with the right shift / fn split. I guess I can take the fn from numpad on a 104 set (1x) but what about the small shift?
4) Was looking into this keyset to go with it:
https://www.massdrop.com/buy/blank-pbt-keycaps
Re: Worth it? Infinity x GMK 3Run 60% Massdrop
« Reply #1 on: Thu, 20 October 2016, 21:10:32 »
I've heard that it's fine, but it can take a while. I think the soldering is outsourced.
Yes. That's a REALLY good price for a metal case.
Most thick PBT sets now have the 1.75x/1x shift/fn combo. If you're struggling to find one, most recent GMK sets also come with them.
I /think/ that set has a 1.75x rshift. Hard to tell from pics, and it's not listed. Looks like there might be one, though.
Offline iLLucionist
  • Topre is Love.
« Reply #2 on: Fri, 21 October 2016, 06:43:16 »
Any idea HOW LONG it would take realistically? I'm trying to search for it but out of luck so far. Perhaps I'm searching in the wrong places.
Offline FuriousGeorge
« Reply #3 on: Fri, 21 October 2016, 10:14:29 »
No way to know with Massdrop. I ordered my Infinity on May 22 last year and received it November 4. I'd hope this run doesn't take that long, but you just never know. I ordered mine assembled and haven't had any problems with it. I really like my infinity and it's become my full time work board. The hacker layout may be a challenge for keys, but the standard layout isn't bad at all. The short shift and row 2 backspace definitely seem to be becoming more popular and most recent sets have featured them.
Offline chuckdee
« Reply #4 on: Fri, 21 October 2016, 10:40:08 »
That's because that's not how you format it - use ?mode=guest_open, i.e.
https://www.massdrop.com/buy/infinity-keyboard-kit?mode=guest_open
Offline iLLucionist
  • Topre is Love.
« Reply #5 on: Fri, 21 October 2016, 19:10:29 »
Thanks! I must've gotten it wrong somewhere.
Offline iLLucionist
  • Topre is Love.
« Reply #6 on: Fri, 21 October 2016, 19:11:08 »
Last thing I'm wondering about... Zealios Purple or Clears?????
