Author Topic: Cherry G81-8308 LPAGB (Cherry MY)  (Read 10366 times)
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« on: Sat, 22 October 2016, 11:42:29 »
A programmable Cherry keyboard this week, this one certainly is a nice idea.... :)
Offline klennkellon
  • I like bottoming out
Re: Cherry G81-8308 LPAGB (Cherry MY)
« Reply #1 on: Sun, 23 October 2016, 08:58:23 »
Cherry MWHYYYYYYY
Offline c2j2
« Reply #2 on: Mon, 04 December 2017, 06:39:03 »
Hi,
you don't by chance still have that keyboard?
I once had three, but there's only one remaining (well after maaaany years they are allowed to give up) and I'm searching everywhere for new ones...
Christian
Offline chyros
  • a.k.a. Thomas
« Reply #3 on: Mon, 04 December 2017, 06:58:40 »
Hi,
Christian
Yeah, I still have it, but would you really want one? xD
Offline Wall Street
« Reply #4 on: Mon, 04 December 2017, 21:38:22 »
Believe it or not, if you use a G81 for an extended period of time, you start to get the MY switch mojo.  I have been using one daily at work for the past four years.  After extensive use you realize that the whole point of the MY switch is that you don't bottom it out and then once that realization sets in the mushiness at the bottom of the travel is no longer an issue (and the huge spring weight in the last mm of travel helps prevent bottom out).  Granted, I wouldn't pick the MY switches over the buckling springs I use at home.
Offline klennkellon
« Reply #5 on: Tue, 05 December 2017, 01:59:45 »
I thought MY had to be bottomed out to actuate anyway?
Offline Wall Street
« Reply #6 on: Tue, 05 December 2017, 17:04:09 »
It actuated about half way. The leaf spring can still bend significantly further after it is pushed into the membrane.
Offline klennkellon
« Reply #7 on: Wed, 06 December 2017, 02:04:58 »
I see. Well at least MY still do that.
I actually ordered a G81 I snagged with doubleshots. I finally get to try Cherry MY as a bonus!
