Author Topic: Lubing linears  (Read 2262 times)
Offline forevermadrigal
Lubing linears
« on: Sat, 22 October 2016, 19:50:45 »
Hey guys! I hope you guys are having a wonderful weekend. So I'm deciding to try out some gateron blacks on my rs68 so I can save my my zealios whenever I get a chance to get my hands on a 96 board. What kind of lube is good for blacks? Any kind of advice/opinions/feedback/things you've noticed is welcome. Thanks so much!! I hope I love the linear life.
Offline aaron6301
  • Pixel Pusher
Re: Lubing linears
« Reply #1 on: Sat, 22 October 2016, 21:25:19 »
Personally, I've favored Krytox 103 for the housing, stem rails, and stem plunger while using Vitrinox Multitool for the springs.
I tend to only use thick lube for tactile switches and stab housings/sliders.
Sent from my SAMSUNG-SM-G925A using Tapatalk
Offline pr0ximity
Re: Lubing linears
« Reply #2 on: Sat, 22 October 2016, 21:27:11 »
Personally I think I'd only lube springs for Gat Blacks, they're quite soft and smooth already.
Re: Lubing linears
« Reply #3 on: Sat, 22 October 2016, 21:32:55 »
Is krytox like impossible to find? I can't find any anywhere
Offline aaron6301
  • Pixel Pusher
Re: Lubing linears
« Reply #4 on: Sat, 22 October 2016, 21:46:16 »
I found some on Amazon a while back.
Other than some sound dampening, I think the difference is negligible. Like yourself, I think the blacks, yellows, and linear clears are pretty good right out of the box
Offline dilbertprogrammer
  • Keyboard Connoisseur
