Author Topic: Whitefox case and plate  (Read 1704 times)
Offline garage_logician
« on: Sun, 23 October 2016, 17:35:47 »
I am just about to order the case (aqua) on MD for the Whitefox and the plate from Sentraq.  It is not ideal since I am hoping the two match, so before I do I wanted to ask if there were any other case/plate alternatives available for the WhiteFox.
Offline xondat
  • i'm not a star
Re: Whitefox case and plate
« Reply #1 on: Sun, 23 October 2016, 18:09:00 »
Unless you create a custom case, those are your only options.
