Author Topic: [IC] Switch Top Removal Tool - PAUSED  (Read 8434 times)
Offline Brammm87
« on: Mon, 24 October 2016, 02:01:06 »
Mechanicalkeyboard.com sells a tool that makes it easy to open the tops of your key switches.
Shipping from them outside the US is fairly costly, which is why I consider doing a group buy, to cut costs.
I have previously bought a batch of 20 and sold these successfully over on /r/mechmarket. In the previous batch, cost ended up being €15 including VAT and non-tracked shipping in Europe. Shipping outside EU is €2 more. Cost for this round will hopefully be a little lower. I am also in talks with the super nice people from mk.com to see if we can get a discount.
Maximum allowed tools would be 4, so they all fit in a bubble mailer and make my life easy.
The interest check definitely showed me there's a high demand for this. However, I am currently in between two moves and back at my parents, which made me realize that if I do a GB now, I couldn't pull it off successfully.
I will probably revisit this early next year and make it happen then.
« Last Edit: Sat, 19 November 2016, 15:45:02 by Brammm87 »
pls gief bbv2
Offline iFreilicht
Re: [IC] Switch Top Removal Tool
« Reply #1 on: Mon, 24 October 2016, 03:43:05 »
I'm in, just one question: If you say "One" tool is that a single one or a pair? Because as I understand it, you always need a pair to open the switch, right?
Sentraq S60-X, dyed blank PBT keycaps, Gateron Browns
Offline Brammm87
« Reply #2 on: Mon, 24 October 2016, 04:10:06 »
They come in pairs, the two of them are considered "one". I know, it's confusing :p
pls gief bbv2
Offline Eszett
« Reply #3 on: Mon, 24 October 2016, 04:18:11 »
@Freilicht I guess noone would sell you one metal piece alone, since you need two of them. Well, theoretically you could, but that would be cumbersome.
@Bramm Just filled the order form ...  :thumb:
Offline iFreilicht
« Reply #4 on: Mon, 24 October 2016, 05:04:48 »
Ok great, filled out the form! Pretty cool that you make this happen. The need for these just emerged last week or so, so it's perfect timing :D
Offline tobsn
« Reply #5 on: Mon, 24 October 2016, 06:49:32 »
I'm in!
Offline LeoChien
« Reply #6 on: Mon, 24 October 2016, 07:56:18 »
oops! It is only compatible for PCB mounted MX switches.
Offline Brammm87
« Reply #7 on: Mon, 24 October 2016, 11:21:11 »
If your plate allows opening of switch tops, they work on those too, but as said, your plate needs to allow it. Most custom plates allow this, however OEM plates often don't (like WASD, DAS, Varmilo etc..).
pls gief bbv2
Offline tobsn
« Reply #8 on: Mon, 24 October 2016, 11:23:17 »
yeah those are the same switches - the difference would be if the switch plate is above or below covering the top part of the switch.
Offline kawasaki161
« Reply #9 on: Mon, 24 October 2016, 12:48:15 »
A lot of high-end (mostly Korean) custom boards do als not allow for this, and tbh. I've never seen any OEM board that supports switch top removal.
On another note, I bought one of those tools from his first run (if you could call it that) and had a great experience with both the product and the seller, I can definitely recommend it!
Offline Chewypost
  • Bacon PanCAAAKES
« Reply #10 on: Tue, 25 October 2016, 08:34:26 »
I'm down. Their shipping is ridiculous going to Canada. Hopefully it won't be an arm and a leg
Hana DSA - Duck Octagon V2| Ducky Mini - MX Red
_____________________________________
Offline kawasaki161
« Reply #11 on: Tue, 25 October 2016, 08:46:00 »
Just a reminder that their shipping on very small orders is very buggy, if you order something that fits into a bubblemailer (springs, stabs, etc.) and it shows a ridiculous price under "calculate shipping" you should just shoot them an e-mail and they will get you their best price. This comment is not meant to keep you from joining this GB, but to clear things up, as I was also slightly annoyed by their strange shipping prices.
Offline Brammm87
« Reply #12 on: Tue, 25 October 2016, 09:47:18 »
Can confirm. They're super nice people when you shoot them an email.
pls gief bbv2
Offline menuhin
« Reply #13 on: Tue, 25 October 2016, 16:37:49 »
I also want one of those.
Is it possible to add also some other items from Mechanical Keyboards?
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline Chewypost
  • Bacon PanCAAAKES
« Reply #14 on: Wed, 26 October 2016, 08:47:34 »
I have emailed them in the past but never got a reply. I'll try again since you guys have had good experiences with it :P
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
« Reply #15 on: Wed, 26 October 2016, 09:10:20 »
Interested  :thumb:
Offline Brammm87
« Reply #16 on: Thu, 27 October 2016, 01:46:53 »
No, sorry.
pls gief bbv2
Offline feralfoo
  • Software developer and mech keyboard nut
« Reply #17 on: Thu, 27 October 2016, 04:13:40 »
Up to now have been using the wire from a binder clip, bend into shape with pliers. Totally in for a couple pairs of these though!
HHKB Pro JP + Hasu controller, Realforce RF87U55G, G60 Retro, QK65
Offline Eszett
« Reply #18 on: Sun, 13 November 2016, 23:39:23 »
We have November now, any news of progress?
Offline repuls0r
« Reply #19 on: Mon, 14 November 2016, 12:26:37 »
is the buy still open? no idea how i missed this and would love to join if its still possible.
Matrix 8XV1.0  |  FMJ 80  |  SKOG  |  TGR Jane CE  |  Orion V2  |  Mech27  |  LZCP  |  TXCP  |  CPSQ  |  TX1800
Offline kawasaki161
« Reply #20 on: Mon, 14 November 2016, 12:41:23 »
It didn't even start, you didn't miss it (yet).
Offline Brammm87
« Reply #21 on: Sat, 19 November 2016, 15:42:42 »
pls gief bbv2
Offline iFreilicht
Re: [IC] Switch Top Removal Tool - PAUSED
« Reply #22 on: Mon, 28 November 2016, 11:41:03 »
Better do it right than force it now, thank you for being honest.
I can certainly wait for a bit, good luck moving!
