Author Topic: Black and purple keycaps?  (Read 6969 times)
Offline shadowstar2417
« on: Tue, 25 October 2016, 01:35:59 »
I've been looking for a set of keycaps like the Bro Set, though in PBT.
They don't have to have legends, they can be blanks, all I'm looking for is a pbt set of black keycaps with purple mods.
I've been looking for months, and nothing like this seems to exist.
Any sets like this, or will I have to dye my own or spend $200 on mixing 2 sets? Looking for darker purple (violet), not lavender.
Re: Black and purple keycaps?
« Reply #1 on: Tue, 25 October 2016, 02:34:34 »
Can either try and grab a bro set second hand or pray that the black lotus set that's in IC phase goes to GB.
« Reply #2 on: Tue, 25 October 2016, 02:44:23 »
I would try to get a bro set, but I don't want ABS keycaps. I tend to sweat a lot especially while playing games, and my current set of ABS caps started to shine after only about 3 weeks. I'm assuming the black lotus set is going to be ABS too?
Offline Crapbag
« Reply #3 on: Tue, 25 October 2016, 08:41:06 »
I don't think you can do artisans in PBT.
« Reply #4 on: Tue, 25 October 2016, 11:17:33 »
Not looking for artisans, I mean a full set of keycaps. Black alphas with purple mods.
« Reply #5 on: Tue, 25 October 2016, 11:19:22 »
I don't know of any pbt sets like that. Dig around and see if you can find 2 tar had sets, one in black, one in lavender. That probably won't run you much more than $60.
Offline xondat
  • i'm not a star
« Reply #6 on: Tue, 25 October 2016, 11:20:36 »
If you're fine with RCB, then PMK do blank DSA PBT sets. Otherwise what you're looking for doesn't exist.
« Reply #7 on: Tue, 25 October 2016, 11:21:27 »
« Reply #8 on: Tue, 25 October 2016, 11:24:17 »
I don't really like that color purple, too light for me. I've been looking at PMK for about a week now, think I'm just going to get white mods and dye them myself.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #9 on: Wed, 26 October 2016, 07:45:14 »
http://www.geekkeys.com/keysets/
This. I was about to link to the same thing!
OP, blanks are here for $60.
Offline menuhin
« Reply #10 on: Wed, 26 October 2016, 07:59:57 »
The purple color looks real sexy.
Unfortunately it's lacking HHKB support - lacking the smaller (purple) backspace on R3. Just one key more.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
« Reply #11 on: Wed, 26 October 2016, 22:53:06 »
seen these before, wish the alphas came in black...
might just order this set only for the mods.
Offline Minnie2
« Reply #12 on: Tue, 01 November 2016, 00:32:33 »
In China's Taobao,there's a purple cap called Zen may fit your requirements(PBT).
    A Bro Caps Fan
Just wanted to make sure everyone sees that information. A lot of people missed it ;)
