Author Topic: Injection molding keycaps  (Read 2976 times)
Offline lrochfort
« on: Tue, 25 October 2016, 12:37:54 »
Hello all,
My first post here.
I recently joined a hackspace that has a Boxford 2.5d CNC mill and an injection molding machine.
Are there any tutorials or design templates that would help me make my own keycaps?
Ideally I'd like to make some spherical caps but I don't have any as a reference.
Cheers,
Laurence
Re: Injection molding keycaps
« Reply #1 on: Tue, 25 October 2016, 12:45:32 »
You might want to check around in the "making stuff together" subforum.
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #2 on: Tue, 25 October 2016, 12:47:18 »
You are going to want to do some research into injection molding as plastics can be very finicky. Mold design, sprue setup, the channels for the plastics all need to be made properly to allow for proper molding of caps.
Offline Pennyz
  • Vegeta
« Reply #3 on: Fri, 28 October 2016, 09:34:01 »
You can refer to some cartoon characters.
I ♥ Night Caps.  I ♥♥♥ Bro Caps
Offline Crapbag
« Reply #4 on: Fri, 28 October 2016, 09:58:53 »
Do you have access to a 3D printer?
Offline Niomosy
« Reply #5 on: Fri, 28 October 2016, 10:58:02 »
To add to that, be prepared on the cost of molds as they're not cheap.  You're either using aluminum or steel with steel molds being particularly costly.  You'll also want to make sure the cap designs you've got are solid before committing them to metal and likely accepting that the first round won't really be the final product.
In terms of templates, you might want to talk to Matt3o and see if you can use the designs he's got.  They're for hi-profile spherical keycaps based on IBM beamspring caps and not currently designed around doubleshot but it might be a good starting point unless someone's already got some files saved for other cap profiles.
