Author Topic: Will these keycaps fit?  (Read 3239 times)
Offline bexleycorona
« on: Wed, 26 October 2016, 18:44:10 »
Hey guys, I'm thinking of changing out the stock keycaps on my Rosewill RK-9000 v1 (http://www.newegg.com/Product/Product.aspx?Item=N82E16823201040). Will these fit on there?
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1806
I'm mostly worried about the sizes since I'm not sure what size the spacebar is.
GE Marquette | Rosewill RK-9000 | Rosewill Apollo 9100 | Realforce 87U "EK Edition" 45g Uniform | Unicomp Ultra Classic Black Buckling Spring | Realforce 87U SE07T0 Variable | Dolch PAC65
Re: Will these keycaps fit?
« Reply #1 on: Wed, 26 October 2016, 20:47:04 »
Fortunately for you, the RK9000 came with a standard layout. Your spacebar is 6.25x, for future reference.
Short answer: Yes.
Offline seville57
« Reply #2 on: Thu, 27 October 2016, 09:09:22 »
You can check here: http://www.maxkeyboard.com/mechanical-keycap-layout-and-size-chart.html
As you can see Ducky and your Rosewill  RK-9000 v1  have  standard bottom row sizes.
« Last Edit: Thu, 27 October 2016, 09:15:14 by seville57 »
« Reply #3 on: Thu, 27 October 2016, 21:02:07 »
Thank you guys, that really helps out!
I also have a Rosewill Apollo 9100 that I just purchased. According to that link the bottom row isn't standard it seems?
Offline seville57
« Reply #4 on: Sat, 29 October 2016, 03:21:02 »
Hi
 Rosewill Apollo 9100 (I hope this is the k - board you're talkin about)
So no, it has non standard bottom row.
My Ducky One RGB YOTG , with standard bottom row.
« Last Edit: Sat, 29 October 2016, 03:31:04 by seville57 »
« Reply #5 on: Sat, 29 October 2016, 10:35:28 »
Non standard bottom row. You can probably get away if you buy a set with a Tsangan kit.
Offline Pennyz
  • Vegeta
« Reply #6 on: Mon, 31 October 2016, 01:07:25 »
Glad you got the answer here.
I ♥ Night Caps.  I ♥♥♥ Bro Caps
