Author Topic: Apple iic with ALPS Amber switchs?  (Read 3390 times)
Offline LifeIsOnTheWire
« on: Fri, 28 October 2016, 10:28:27 »
http://www.ebay.com/itm/Apple-IIc-as-is-/182327663009?hash=item2a739359a1:g:IkQAAOSwHsRYDmxr
Found someone selling an Apple IIc, and bidding is at $35 right now
One of the keycaps broke off, and you can see it is the model with ALPS amber switches.  Although the model number of the computer doesn't match the models that were shipped with the ALPS keyboards.  Perhaps it was swapped at some point?
Offline cribbit
Re: Apple iic with ALPS Amber switchs?
« Reply #1 on: Fri, 28 October 2016, 14:10:15 »
Depending when it broke it could be discolored plastic of another color.
Depending how it broke and what switch was originally there it could be something that looks like alps, but isn't.
If this was cheaper I'd buy it just to gamble, but it looks like someone else is already bidding anyways.
I typed this post on my Slanck. I also developed a stronger, cleaner, easier handwiring method.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #2 on: Fri, 28 October 2016, 15:24:17 »
It's amber Alps.
« Reply #3 on: Fri, 28 October 2016, 19:46:17 »
Its looks fairly ALPS-like, considering the pre-ALPS Apple IIc switches look quite different
