Author Topic: [IC] G20 Semiotic (Currently available from PMK)  (Read 136226 times)
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
Re: [IC] G20 Semiotic (Currently available from PMK)
« Reply #350 on: Mon, 06 February 2017, 18:49:19 »
Now that is an Alien Keypad, even the Queen would be impressed   8) .
Offline oHimari
« Reply #351 on: Thu, 09 February 2017, 10:20:13 »
Semiotic on my RS96.
Offline Tom_Kazansky
  • Oblivion Knight
« Reply #352 on: Thu, 09 February 2017, 10:26:38 »
wow  :thumb:
Offline mogo
« Reply #353 on: Thu, 09 February 2017, 11:42:40 »
Good lord, that is a thing of beauty.  :thumb:
Offline zslane
« Reply #354 on: Thu, 09 February 2017, 12:21:39 »
Stunning!
I really like how each person can arrange the symbols in a way that makes unique sense to them. In effect, the arrangement of the symbols reflects the mind of the owner in a way you don't really get with any other keyset.
Offline Blazestorm
« Reply #355 on: Tue, 14 February 2017, 11:42:35 »
Ordered the full works from PMK last night... No idea what I'll use them for but they look so unique and I wanted to try G20 anyways. Wonder how they'll feel on the Realforce RGB...
Offline zslane
« Reply #356 on: Tue, 14 February 2017, 11:54:22 »
I'll be very interested to hear what you think of them on the RealForce RGB. I could put them on mine, in order to see for myself, but I just can't bear to take off the SA keycaps I have on now.
Offline Blazestorm
« Reply #357 on: Wed, 15 February 2017, 23:27:39 »
Lazy/quick/blurry pictures.
Not sure about the G20 profile. Thought I'd like it more at first, but might just need to use it more.
Also I don't think the black case goes too well w/ the white caps...
Offline parablol
« Reply #358 on: Thu, 16 February 2017, 10:05:04 »
Beat me to it! Atreus was one of the first things I was thinking of using this set on.
Looks great and I applaud you taste in keyboards.
Perhaps a future iteration with a white-acrylic body to match? That's a combination I've fantasized about.
Offline sems
« Reply #359 on: Thu, 16 February 2017, 10:33:15 »
I'm currently selling Atreus to fund an HHKB, but if it doesn't sell before I travel Japan, I will do an acrylic case for it.
My idea was actually just to get top and backplate in white acrylic and sandwich the wood in between!
I cannot get the Ponoko website working I don't know why to get a quote.
I also want to modify the usb cable, white sleeve would look dope on this!
Offline zslane
« Reply #360 on: Thu, 16 February 2017, 12:15:25 »
I hear ya.
I had the same issue matching up my Round 6 Space Cadet keycaps with the RealForce RGB. My solution was to paint the case top white.
Offline Blazestorm
« Reply #361 on: Thu, 16 February 2017, 13:40:32 »
My wife loves the profile/design though, so she'll probably steal these from me. And she likes the white on black look, so it all works out.
I might steal some extra symbol caps for a macro board though :D
Also the caps look much better w/uniform LED colors, not the rainbow. I'll take some better pictures tonight.
Offline Blazestorm
« Reply #362 on: Thu, 16 February 2017, 22:20:10 »
It's funny how my brain is already starting to associate the certain symbols with the corresponding letters.
Offline zslane
« Reply #363 on: Fri, 17 February 2017, 00:18:21 »
I wonder what it would look like with white LED light beaming from underneath them. I wonder if it would make the separation between the keys sort of disappear.
The idea of coloring sections of keys is interesting.
Offline Blazestorm
« Reply #364 on: Fri, 17 February 2017, 00:35:16 »
A little exaggerated from overexposing, but still looks pretty good in person =)
To make the gaps disappear, you might need the keys themselves to also get lighting from on top.
« Last Edit: Fri, 17 February 2017, 00:36:58 by Blazestorm »
Offline iFreilicht
« Reply #365 on: Fri, 17 February 2017, 02:21:52 »
Hot damn that looks amazing.
How could that be done? I've never seen a keyboard where the keys are being lit from above. Or am I misunderstanding something?
Sentraq S60-X, dyed blank PBT keycaps, Gateron Browns
Offline zslane
« Reply #366 on: Fri, 17 February 2017, 12:13:29 »
I think he means from external lighting used for the purpose of the photograph.
Offline Blazestorm
« Reply #367 on: Fri, 17 February 2017, 12:19:57 »
Right, so not really going to happen :( unless they had semi translucent g20 caps to dye sub.
Then the backlighting might work
« Last Edit: Fri, 17 February 2017, 12:21:39 by Blazestorm »
Offline iFreilicht
« Reply #368 on: Fri, 17 February 2017, 13:46:23 »
That would be pretty awesome for SP to add to their catalogue of PBT colours. Or maybe, just maybe, they'd add POM to their portfolio, I heard that's used in backlit PBT caps for the translucent part.
That would certainly take this set to the next level, but I'm sure it would also open options for a lot of other interesting sets.
Offline pixelpusher
« Reply #369 on: Mon, 27 February 2017, 13:59:35 »
I just got my CoolerMaster XT board painted beige!  I was in the process of putting the a full set of semiotic on, but I had to come back to work.  I'll update with photos tonight.  It looks pretty awesome.  Really makes me wish there were some better options for beige cases.  The paint job is okay, but it's certainly not "premium."
Also, I didn't notice before because I didn't have the numpad kit installled, but it is a bit goofy the way the "Enter" and "+" keys are made.  I guess SP doesn't have G20 molds for vertical 2u caps?  I'm sure we talked about it sometime, but I had forgotten.
Pics tonight!
Offline zslane
« Reply #370 on: Mon, 27 February 2017, 14:06:57 »
You are correct on both counts.  ;)
Offline Blazestorm
« Reply #371 on: Mon, 27 February 2017, 16:32:44 »
Yea that did throw me off a bit when I went to put them on. But it's only 2 keys on a specific layout so I guess it doesn't make a lot of sense to do new molds for those.
Offline zslane
« Reply #372 on: Mon, 27 February 2017, 19:16:45 »
Yeah, it's a much bigger deal for ErgoDox users. And if SP were to cater to their needs, they'd need to make both 2u and 1.5u vertical molds.
Offline pixelpusher
« Reply #373 on: Mon, 27 February 2017, 22:01:52 »
Took me another hour to decide the layout.  Too fun!
161616-0
161618-1
161620-2
161624-3
« Last Edit: Mon, 27 February 2017, 22:03:59 by reececonrad »
Offline zslane
« Reply #374 on: Tue, 28 February 2017, 12:28:23 »
Fantastic!  :thumb:
Offline a-c
« Reply #375 on: Thu, 30 March 2017, 14:59:39 »
Mini Semiotic
164357-0
More pictures
Offline zslane
« Reply #376 on: Thu, 30 March 2017, 15:21:19 »
I love it!  :thumb:
Offline pixelpusher
Offline infodroid
« Reply #378 on: Fri, 14 April 2017, 09:49:55 »
I just found out the keyset was featured on Boing Boing a while back, soon after it went on sale.  :thumb:
Offline Photoelectric
« Reply #379 on: Tue, 02 May 2017, 11:51:02 »
Interest Checks section is for gathering community interest and opinions on design only--not for discussions of ongoing group buys.  For ongoing group buys, discussion should be either in the Group Buys and Preorders section in a dedicated thread started by OP or, in this specific case, in the Signature Plastics section of this site (or else please contact Signature Plastics directly).
