Author Topic: Opening the Matias Laptop Pro Keyboard  (Read 2012 times)
Offline megarat
  • (Not My Real Name)
    • http://www.megarat.com
« on: Sun, 30 October 2016, 16:57:51 »
Greetings.  Has anyone here opened up the case for the Matias Laptop Pro Keyboard?  (The one I have is the Mac-specific version, if that makes a difference.)  There are two obvious screws on the bottom, by the case won't open by removing those screws alone, so I'm wondering if I'm missing something obvious (or not-so-obvious).  Maybe it's held together by clips on the interior?  Do I need to use a case cracker tool on this thing?
Thanks, any pointers or information would be appreciated.
Home/Work:  Custom Filco FKBN87Z/EB and SGI 041-0136-001 chimera (original white ALPS, not simplified, rubber-dampened)
Gaming:  Wolfking Warrior with custom-colored layout, HHKB Lite 2 (Rubber dome)
Offline ctm
  • Hello, world!
Re: Opening the Matias Laptop Pro Keyboard
« Reply #1 on: Sun, 30 October 2016, 20:54:32 »
According to this, there are clips on the side of the case. A tool might help.
Coming:
Ellipse Model F F62.
Offline megarat
« Reply #2 on: Sun, 30 October 2016, 23:01:10 »
Terrific, thanks.
