Author Topic: RS84 Issue. Need help please!  (Read 1268 times)
Offline Unwise
« on: Sun, 30 October 2016, 19:54:56 »
Hi Everyone,
Got a used rs84 last August. Been working well for awhile. Suddenly, today none of my keys are registering.
1. The led lights still works however if wobbled incorrectly start flashing and then turn off.
2. Tried on multiple machines and multiple USB ports. None of the devices are recognizing the keyboard.
3. The connector seems to be fine? Doesn't seem loose or anything.
Any ideas on the culprit? Is it just a usb cable issue or is it more likely a connector problem? If a connector problem what are my options?
Thanks so much. Really love this keyboard and don't want to bury it just yet.
Offline chicken
  • Gallus gallus domesticus
Re: RS84 Issue. Need help please!
« Reply #1 on: Sun, 30 October 2016, 20:03:08 »
Did anything significant happen to the keyboard? I would try plugging it in with another cable before anything else.
Offline livingspeedbump
    • KeyChatter
« Reply #2 on: Sun, 30 October 2016, 20:45:53 »
Try multiple cables?
<- My Collection (so far)
