Author Topic: 6.25u or 7u, which spacebar do you prefer?  (Read 28493 times)
Offline Geroximo
« on: Thu, 03 November 2016, 06:26:18 »
I like the style of a 7u spacebar in combination with a 1.5u and 1u bottom row, but the 6.25u just feels better when I hit it off center.
I can't decide ... go for style or go for better feel ...
Which one do you prefer?
Re: 6.25u or 7u, which spacebar do you prefer?
« Reply #1 on: Thu, 03 November 2016, 07:52:47 »
Generally if you go for style, you'll get used to the feel.
Offline Minnie2
« Reply #2 on: Fri, 04 November 2016, 02:50:14 »
I prefer 7u spacebar,i like 84 kbd more.
    A Bro Caps Fan
Just wanted to make sure everyone sees that information. A lot of people missed it ;)
Offline TalkingTree
    • My projects
« Reply #3 on: Fri, 04 November 2016, 06:35:08 »
7u with winkeys.
« Reply #4 on: Fri, 04 November 2016, 14:44:57 »
7u only because of the Winkey-less (or 1u Win keys) layout, but I think 7u is too long. 6u is just about right.
The only reason I'd consider 6.25u space bars again is that artisan space bars seem to be up and coming but only in 6.25u sizes.
Offline y11971alex
  • Looking for Toronto meetup
« Reply #5 on: Tue, 08 November 2016, 19:40:25 »
10u  :p
Offline ideus
  • Björkö.
« Reply #6 on: Tue, 08 November 2016, 20:12:01 »
The best centered is a 6u space bar along with 1.5+1 units modifiers each side.
This makes the point well:
« Last Edit: Tue, 08 November 2016, 20:19:17 by ideus »
Offline Arallu
« Reply #7 on: Tue, 08 November 2016, 20:34:33 »
6.25 cause that's whats on all my keyboards
Offline luckyryan333
  • #There'sNoToolForTyping
« Reply #8 on: Tue, 08 November 2016, 20:40:37 »
both of 'em.  :)
No PaiN, No GaiN
How to order from Taobao from outside of China and WITHOUT an Agent
daily driver: C70 w/ Oblivion
on the way: d65_12/gmkblk_3
Offline slot demon
« Reply #9 on: Wed, 09 November 2016, 03:54:21 »
Whats about, 2,25u+2,75u split spacebar?
Offline Nafs_asp
« Reply #10 on: Wed, 09 November 2016, 19:49:12 »
I kind of see what you mean. I recently built a few boards that use the 1.5/1/1.5/7 bottom row layout after only using 1.25/6.25 previously. The spacebars do feel a bit different, and I'm still getting used to the spacing between ctrl/win/alt, but I love typing on an R5 bottom row and like the more even look:
152548-0
