Author Topic: Planck End Game Case (High Profile) Anodize Color update!  (Read 109164 times)
Offline hansichen
Re: Planck End Game Case (High Profile) FIRST SAMPLE ARRIVED
« Reply #100 on: Thu, 19 January 2017, 04:55:54 »
I am low on money anyway :)
We all are right how :-[
The case looks really good so far, I'd agree that the usb port could have some improvement. Maybe just close it a bit more and post a picture from usb connecter side how it looks right now when it is in standing on the ground. I really like the support of handwired boards :thumb:
Offline neon_tom
« Reply #101 on: Thu, 19 January 2017, 07:20:51 »
That white powder coat looks much nicer than I anticipated it would. I'll definitely pick one of these up at this rate.
Offline hervuli
« Reply #102 on: Thu, 19 January 2017, 10:08:36 »
+1. Would love to see more white powder coat aluminum board options out there in general.
JD40v2 MX Grey | HHKB BKE Heavy | E6-V2 78g Tealios | ZealX60 72g MX Zilent | TGR 910 RE 78g MX Zilent | Singa Vintage MX Black | Octagon V2 MX Grey | Orion V2 MX Clear | Novatouch BKE Extreme
Offline PollandAkuma
« Reply #103 on: Thu, 19 January 2017, 14:00:53 »
Since the Planck will drop soon, I'll get a couple of pcb and plates, and if I like the layout I'll get Case A when it happens. I love this case sooooo much
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #104 on: Thu, 19 January 2017, 14:14:06 »
So, to clarify this: I can just drop my existing Planck like it is (see picture) into that case without removing any parts?
Also: can you update the image links on post #1 — maybe a Tapatalk issue, but I can only see one image.
Pretty sure you'll at least have to remove the bottom part of your case and you'll drop in everything that is attached to the plate.
Offline muten-roshi
« Reply #105 on: Thu, 19 January 2017, 15:01:44 »
Any idea how soon?  :rolleyes:
« Reply #106 on: Thu, 19 January 2017, 15:39:27 »
Before the end of this month, I suppose
Offline muten-roshi
« Reply #107 on: Thu, 19 January 2017, 16:01:45 »
Great I already don't have money
Gesendet von meinem E5823 mit Tapatalk
« Reply #108 on: Thu, 19 January 2017, 16:25:29 »
me too thanks
Offline stoic-lemon
« Reply #109 on: Thu, 19 January 2017, 17:14:06 »
I might pick up a Planck due to Case A. Really hope this turns out good.
Edit: Mobile keyboard led to mangled English.
« Last Edit: Thu, 19 January 2017, 23:50:02 by stoic-lemon »
Offline muten-roshi
« Reply #110 on: Thu, 19 January 2017, 17:45:11 »
If pick up a Planck due to Case A. Really hope this turns out good.
I want one anyway
Offline jebbra
  • jebbra.net
« Reply #111 on: Fri, 20 January 2017, 06:55:30 »
About the USB port, maybe it looks odd because I flip the board. From standard point of view the gap give a nice round gap between the cable head and the case. Will post the pic tommorow :thumb:
I prefer do this slowly and try every option I have here. So don't worry. Will do the GB on times around payday too :p
Offline jebbra
  • jebbra.net
« Reply #112 on: Sat, 21 January 2017, 00:59:46 »
Here's the USB port in use in usual view angle. Looks good right?
158172-0
158174-1
Offline hansichen
« Reply #113 on: Sat, 21 January 2017, 06:34:57 »
Looks good  :thumb:
Offline neon_tom
« Reply #114 on: Sat, 21 January 2017, 08:20:52 »
Gorgeous!
Offline MNICI
« Reply #115 on: Thu, 26 January 2017, 14:10:58 »
Created a GH account just to post here  ;)
White powdercoat looks pretty nice, but a bit plastic-y in my opinion. I would prefer clear/silver anodization myself, but as you said that depends on vendor availibility.
Would it be possible to get raw case B with a little discount? I may find some local place to anodise it on my own...
About USB hole - why not make it smaller like this? This way PCB wont be as visible.
meh.
Offline jebbra
  • jebbra.net
« Reply #116 on: Thu, 26 January 2017, 21:16:21 »
The purpose of having wide usb post is to support hand wiring. Because when handwiring, the micro controller used is placed on the bottom of the case so the usb port is a bit lower. But don't worry, the hollow part won't be visible IRL (look at the photo I take).
I can do raw too since the MOQ for powder coat is quite low, this way I feel more fair for people who want to anodize or treat it whatever they want. One question tho: my CNC vendor said it is better to keep the case oily if you want to coat it later, is this true?
Offline breckstar
« Reply #117 on: Thu, 26 January 2017, 22:07:45 »
Any hope of getting preonic version?
Offline shensmobile
« Reply #118 on: Thu, 26 January 2017, 22:37:31 »
Just created an account to say that I am absolutely in for Case A.  That's pretty much the thing holding me back from grabbing a Planck, I love high profile cases and that one fits the bill.  If you can offer it annodized, or raw I would be elated!
As for keeping the case oily, if it were steel I would say that helps for rust prevention, but for an aluminum case, I'm not quite sure.  I'm an electrical engineer, not a mechanical so I can't help too much here! Sorry!
Offline slot demon
« Reply #119 on: Fri, 27 January 2017, 02:14:57 »
Any update? Case A is a dream, I like also the plain silver look.
Offline jebbra
  • jebbra.net
« Reply #120 on: Fri, 27 January 2017, 04:09:27 »
Yep, after these 2 I plan on making a hipro Preonic case, along with standard plate.
That's nice of you creating GH account just to say it, thank you :) If there's no capable anodize vendor I will offer them raw too, with price reduction. Just confirmed it that it still necessary for aluminum too, as it will prevent oxidation (black specks) on exposed aluminum.
I will go to the vendor tomorrow. Sorry for the long process, I can only do the visit on Saturday because my work :(
Offline breckstar
« Reply #121 on: Sun, 29 January 2017, 19:17:14 »
Sweeeeeeeeeet. Looking forward to it :)
Offline shensmobile
« Reply #122 on: Mon, 30 January 2017, 12:07:28 »
Hey you're doing fantastic work, you deserve the props/thanks/orders!  The fact that you're making Case A compatible with the Planck plate is huge news and awesome design!  I'm eagerly following this thread :)
Offline piercejenkins
« Reply #123 on: Mon, 06 February 2017, 11:41:49 »
When will case A be available for order?
Offline jebbra
  • jebbra.net
« Reply #124 on: Mon, 06 February 2017, 22:03:35 »
Anvil Case must wait longer, I will release Bullet Case 1st and gather feedback from it then proceed to open the Anvil. But the IC won't be as long as this one because when the Bullet release it means I already acquire the right vendor (actually the only vendor missing is anodizing).
Offline Juice_box
« Reply #125 on: Tue, 07 February 2017, 14:11:22 »
I just want to say thanks for going to all this effort of producing these! I can't wait for case A. Good luck with the rest of organising and production :)
Offline stoic-lemon
« Reply #126 on: Wed, 08 February 2017, 06:39:26 »
Hyped for Anvil.
Offline jebbra
  • jebbra.net
« Reply #127 on: Wed, 08 February 2017, 10:17:39 »
Just visited a quite experienced anodize craftsmen this morning and making sample there. Finger crossed he will do the job right since he is on that field since 30 years ago.
Offline jal
  • I can't believe it's not gravy!
« Reply #128 on: Wed, 08 February 2017, 10:56:57 »
So to sum up, both powder coat and hard anodized coloring are quite durable with powder coat potentially be even more scratch resistant.
But powder coat looks plastic (unless the paint is a metallic color itself), and anodizing looks naturally metallic.
It does look plastic, because it is plastic. But powder coat comes in a pretty wide range of options. There are translucent options, metal-flake options, it can be shiny or matte (usually, shiny is done with a clear top-coat), and there is a huge range of colors (but most shops only have a small subset on hand).
In case you're interested in more detail, here's detail on DIY:
http://www.powdercoatguide.com/
And one shop's colors:
https://www.prismaticpowders.com/powder-coating-colors/
For info on anodizing, I recommend starting with the Wikipedia page: https://en.wikipedia.org/wiki/Anodizing .
Disclaimer: I have powder-coated things, but not much because I hate doing it, so I'm no expert. I hate wearing a respirator and waving 15KV around while puffing flammable powder at metal (==spark risk) tends to make me nervous.  And I've never tried to anodize anything. Something about heating an acid bath and then running current through it makes me think I should just play in an alligator pit instead.
Offline jebbra
  • jebbra.net
« Reply #129 on: Thu, 09 February 2017, 05:57:35 »
Okay got a potato pic from the gramps at anodizing vendor  >:D
160040-0
Not yet getting my hands on it, but the pic looks promising :-*
I will pick it up on Saturday.
Offline stoic-lemon
« Reply #130 on: Thu, 09 February 2017, 06:29:14 »
sold! :) haha I hope it's up to your specifications.
Offline Danilo_dk
« Reply #131 on: Fri, 10 February 2017, 12:01:37 »
The anodization looks really good. Is that sample in gray, or is that black? Either way, I want it. I'll probably get both the Bullet and Anvil cases. They both look very good in their own ways.
Offline menuhin
« Reply #132 on: Fri, 10 February 2017, 13:26:52 »
Case A also looks real nice.
I have to remain patient though.  ^-^
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
« Reply #133 on: Fri, 10 February 2017, 18:23:43 »
Nice to see you got some good relations going! That's part of the fun :D
« Reply #134 on: Fri, 10 February 2017, 18:41:36 »
Case A looks amazing. Will have to re-buy a planck I guess.
Offline Danilo_dk
« Reply #135 on: Sat, 11 February 2017, 05:08:46 »
Cases spotted in the wild. Both looking great.
Offline gadzkun
« Reply #136 on: Sat, 11 February 2017, 08:08:42 »
case and anodizing was good already see and touch it, this is the first time i reallly want an ortholinear board. :thumb:
Offline jebbra
  • jebbra.net
« Reply #137 on: Sat, 11 February 2017, 22:49:53 »
Thx mates!
Okay I already have my hands on it and I really love it! But he said there is one more superior anodize method and I want to try it first. And will sample some colors to anodize for final GB offer.
Offline robotmaxtron
« Reply #138 on: Wed, 22 February 2017, 00:57:32 »
I'm really looking forward to this GB.
Offline shinz0
  • i was told there would be cake
« Reply #139 on: Wed, 22 February 2017, 19:15:53 »
this case just made me realize i need a planck in my life.
Offline fatpolomanjr
« Reply #140 on: Thu, 23 February 2017, 00:07:29 »
Have you considered doing a split version after releasing the standard planck case?
Some guys keep on saying they believe in Jesus, and keep doing a lot of shameful things.
Current GH Classified Post (LF Arcade Floor, Garbield and CYM Otter and Keyng)
Offline jebbra
  • jebbra.net
« Reply #141 on: Thu, 23 February 2017, 00:57:11 »
There's ton of keyboard design in my head right now. Including split planck. and I heard OLKB will release split version too in not so distant future. I'll wait for that for now.
Offline jebbra
  • jebbra.net
« Reply #142 on: Thu, 23 February 2017, 00:59:50 »
Damn the formatting is going haywire. Moved to the next post.
« Last Edit: Thu, 23 February 2017, 01:25:56 by jebbra »
Offline simonyunhe
« Reply #143 on: Thu, 23 February 2017, 01:09:33 »
This is really nice, love it!
KeyBs:|RS96-Brown|GS-87-White|DIYer60-Red|VA68M-Brown|GS-ALT71-Blue|IKBC-108-Black|
KeyCs:|SA Carbon R1+2|SA Camping|SA Amazing Chocolatier|SA Commando 88 Ghost|SA Hyperfuse|SA Penumbra|SA Doom|SA Creamy Orange|SA Ocean Dolch|SA Lotus*72|SA Trouble Minds R2|DSA Granite|GMK TA|GMK Soware|XDA Mailstone|GM Ember|
Offline jebbra
  • jebbra.net
« Reply #144 on: Thu, 23 February 2017, 01:28:20 »
Anodize looks nice!
161199-0
161201-1
161203-2
Only little blemish appeared on the edge, that's the rigging problem I need to take care of. Already drop some plate in same material and finish to make color samples  :thumb:
Offline ricyuyc
« Reply #145 on: Thu, 23 February 2017, 04:01:13 »
Awesome! I hope one day you would make this in GH60 form factor.  :thumb:
Offline sems
« Reply #146 on: Thu, 23 February 2017, 08:22:30 »
Anodize looks nice!
Whoa! Color me impressed!
« Reply #147 on: Thu, 23 February 2017, 14:56:46 »
Nice! I really like this aluminum design, plus who wouldn't want two blocks of metal for self defense? Weapon of choice IMO.
Offline aznreaper
« Reply #148 on: Sat, 25 February 2017, 20:34:47 »
That anodized sample has me liking the look of that second design. I haven't really like the big bezel boards like the extent, but the tampering seems like just enough to start growing on me! Would definitely like to see the bullet case sample with the anodizing. Powdered white makes it look too much like plastic from the pictures
Offline jchan94
  • Keyclack Inc
  • Please email jchan@keyclack.com. PMs are disabled
    • KeyClack
« Reply #149 on: Sat, 25 February 2017, 21:40:55 »
Hey that update looks pretty nice! Goodluck with this :D
Support Email: support@keyclack.com
Did you miss something from us?
- Sign up for our Mailing List: https://eepurl.com/coAJ5r
