Author Topic: big-ass enter?  (Read 6694 times)
Offline pixelpusher
big-ass enter?
« on: Sun, 06 November 2016, 13:17:44 »
Does anyone know of a modern PCB that would support ansi layout that uses the big enter key (the one that looks like an ISO enter but it's a backwards L)?
Also, I haven't been able to find a keycap manufacturer who still makes a keycap this shape.  Any ideas?  Other than salvaging old parts?
Offline seville57
Re: big-ass enter?
« Reply #1 on: Sun, 06 November 2016, 15:13:00 »
I have this in a set from Maxkeyboards but buyin a set for usin 1 keycap, I don't think so.
http://www.maxkeyboard.com/max-universal-cherry-mx-translucent-clear-black-full-keycap-set-front-side-print.html
http://www.maxkeyboard.com/max-universal-cherry-mx-translucent-clear-black-full-keycap-set-top-print.html
http://www.maxkeyboard.com/max-universal-cherry-mx-translucent-clear-black-full-keycap-set-blank.html
« Last Edit: Sun, 06 November 2016, 15:27:58 by seville57 »
Offline alienman82
Re: big-ass enter?
« Reply #2 on: Sun, 06 November 2016, 15:29:06 »
removed.
« Last Edit: Thu, 01 March 2018, 13:44:13 by alienman82 »
Re: big-ass enter?
« Reply #3 on: Sun, 06 November 2016, 15:48:12 »
One problem with "Big-ass Enter" keys is that unlike other keys, the arrangement of the stabiliser(s) is not entirely standardized.
Max Keyboards, Gateron and Tai-Hao have keycaps that look as if they are compatible with Steelseries' keyboards. Those have stabilisers like ANSI Enter keys and a long peg in the middle of where a 1.5u Backslash key would be.
The lower part of the keycap should be compatible with an ANSI keyboard... but I think that the peg is too wide to fit inside the drill hole in the PCB for the Backslash key's switch. The best solution would probably be to mod it: cut it short, sand it to the exact size and then cut a cross in it to accept a Cherry MX switch.
BTW. Cherry itself has made "Big-ass" backwards-L Enter keys but those have had the stabiliser bar on the vertical - in the middle of the 1.5×2 rectangle. They are not compatible with either ANSI or ISO.
« Last Edit: Sun, 06 November 2016, 15:52:20 by Findecanor »
Offline pixelpusher
Re: big-ass enter?
« Reply #4 on: Sun, 06 November 2016, 15:50:31 »
There is this board if you wanted big ass brand new or something:
https://www.amazon.com/SteelSeries-6Gv2-Mechanical-Gaming-Keyboard/dp/B0038X3ZVM
oh, nice.  I've never seen that steelseries board.  Of course it's full size :(  boo
Offline alienman82
Re: big-ass enter?
« Reply #5 on: Sun, 06 November 2016, 15:53:28 »
removed.
« Last Edit: Thu, 01 March 2018, 13:44:11 by alienman82 »
Offline pixelpusher
Re: big-ass enter?
« Reply #6 on: Sun, 06 November 2016, 16:19:18 »
not to mention that right shift. very odd
What the what?  I didnt even see that.  I thought the big enter split delete into backslash and delete both 1x1.  That's odd indeed
Offline alienman82
Re: big-ass enter?
« Reply #7 on: Sun, 06 November 2016, 16:24:38 »
removed.
« Last Edit: Thu, 01 March 2018, 13:44:10 by alienman82 »
