Author Topic: Realforce 87UW cleaning/maintenance  (Read 5097 times)
Offline durainello
    • Free cheap and fast International shipping solution to fellow Singaporean.
« on: Sun, 06 November 2016, 19:35:04 »
Good Day,
I've been using my RF87U white for a year and half and using wet wipes for weekly cleaning. I notices that the top cover and caps are getting yellowish (Yes, I'm a smoker) despite weekly maintenance. I read that the keycaps can be clean by soaking into denture tabs and i'm wondering can i also do it with the top cover as well. Apologies for the poor english.
Thanks.
Offline 1391406
Re: Realforce 87UW cleaning/maintenance
« Reply #1 on: Sun, 06 November 2016, 20:38:56 »
I've never done it, but I don't see why you can't.
Offline Macsmasher
« Reply #2 on: Mon, 07 November 2016, 14:19:58 »
I use an ultrasonic cleaner for PBT keycaps with hot soapy water. I already have one for reloading ammo, but you can pick one up for $30 or so on Amazon or try Harbor Freight. They're handy to have for lots of things. It's the best thing I've found to dislodge oils in the textured surface of the keycap.
« Reply #3 on: Mon, 07 November 2016, 17:22:42 »
Realforces naturally yellow a bit with time. Mine is pretty clean still, as I'm a non-smoker and it spends a lot of time in the box.
There are plenty of guides to whiten it again.
Offline czarek
  • Keep the momentum going!
    • FalbaTech
« Reply #4 on: Tue, 08 November 2016, 10:45:33 »
When my keycaps get dirty I just clean them in a dishwasher on the "eco" setting that is slightly lower temperature than usual. I put them in those bags you use to wash your sneakers. After an hour, they're clean like new.
Only time I had problem was when I cleaned stock Filco keycaps this way. They didn't melt but got discolored in a nasty way, but they were crap quality anyways. Not sure why I even bothered washing them :)
I do that regularly on black Topre keys (HHKB and Realforce), white Topre keys (HHKB), IBM Model M/F keycaps and charcoal EnjoyPBT blanks from Gateron as those are the things I use mostly.
« Reply #5 on: Tue, 08 November 2016, 13:00:23 »
Just stop smoking.
Offline 1391406
« Reply #6 on: Tue, 08 November 2016, 13:40:17 »
The Realforce case is made of ABS so it may eventually start to yellow whether you smoke it or not.
