Author Topic: Only Caps lock and Control key are working  (Read 1510 times)
Offline FruizaH
« on: Mon, 07 November 2016, 19:07:16 »
I recently got an Apple Standard Keyboard (M0118)which I hooked up to my PC via an iMate adapter  and all keys except for the Caps lock and Control key are not working.
When I plug in a second, fully functioning keyboard simultaneously this problem occurs on that keyboard as well.
I also have an AEK II which is functioning flawlessly with the same adapter.
Any ideas on how to solve this problem?
Offline DanB
Re: Only Caps lock and Control key are working
« Reply #1 on: Mon, 07 November 2016, 22:24:52 »
Maybe the board itself is damaged
Kingsaver, Koala
Offline Macsmasher
« Reply #2 on: Mon, 07 November 2016, 22:49:20 »
It can't be a coincidence that the same thing is happening with two keyboards. I'd guess the adapter. And try another USB port.
Offline hurst
« Reply #3 on: Mon, 07 November 2016, 23:11:25 »
Isn't iMate PS/2?
