Author Topic: Anyone used a "Sodial" brand Teensy 2.0?  (Read 3109 times)
Offline LifeIsOnTheWire
« on: Tue, 08 November 2016, 07:22:34 »
https://www.amazon.ca/USB-development-board-keyboard-experiment/dp/B01JFXS2X4/ref=sr_1_6?ie=UTF8&qid=1478610026&sr=8-6
It has an ATMEGA32U4, so it should be able to run TMK or QMK.  Can anyone think of a reason this might not be a good idea?
I have an Amazon giftcard, otherwise I would be ordering a PJRC Teensy
Offline wodan
Re: Anyone used a "Sodial" brand Teensy 2.0?
« Reply #1 on: Tue, 08 November 2016, 07:33:45 »
There have previously been third party "Teensy" boards but they did not have the original PJRC bootloader and work more like a ProMicro than a real Teensy when it comes to flashing. What makes the Teensy so special is the bootloader and the high pinout count compared to the ProMicro which sells for  ~5$
« Reply #2 on: Tue, 08 November 2016, 09:08:46 »
Thanks for the reply.  I haven't flashed a Teensy before.  Without the PJRC bootloader, will I run into any difficulty?
How would my flashing experience differ between having a PJRC versus a non-PJRC?
Offline a-c
« Reply #3 on: Tue, 08 November 2016, 11:28:34 »
This listing by Karlsson Robotics is a genuine Teensy 2.0. https://www.amazon.com/gp/product/B00NC43256/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=AFBMYHRQ9KU5H Also ships from USA, not China like the fake one you linked to.
https://forum.pjrc.com/threads/23601-Official-Distributors
Offline 27.9.2016
« Reply #4 on: Tue, 08 November 2016, 12:01:23 »
What do you think about this one i have ordered two pieces.
I didn't try to run TMK or QMK because I am programming tennsy in arduino language and for now keyboard matrix work.
https://www.aliexpress.com/item/Teensy-2-0/32594112031.html?spm=2114.13010608.0.0.dmJ0La
« Last Edit: Tue, 08 November 2016, 12:06:07 by 27.9.2016 »
« Reply #5 on: Tue, 08 November 2016, 14:31:37 »
It's still a fake, and given the wonkiness of the button not a great one.
Either you want to support the original designers and get the tiny bootloader or you just want a cheap controller that will get the job done, which those should.
