Author Topic: [IC] TGR-910 65% masterrace | supported layouts added  (Read 106114 times)
Offline yuktsi
  • Colour my life with the chaos of trouble
« on: Fri, 11 November 2016, 08:26:22 »
Logo will be repositioned
Hello peeps, it has been more than a year since Jane CE. Many things happened during this period of time. ivan went missing, juahenza rised as the pride of Asia, Trump became POTUS, still no re-run of digilog (maybe I should try that someday). All these aside, I hope you guys are well.
About TGR 65% aka 910
65% is probably the best layout, be it for Overwatcher or casual type. There was a period of time when I used only the HHKB. LZ-SQ is the one that pulled me back from the dark side. TGR-910 is designed to provide the best typing feeling in a compact layout, while maintaining a effective number of keys. The design (?) is highly influenced from the older Korean customs.
Design
Unlike latest trends in keyboard hobby, there is nothing fancy or loud in the TGR design. The classy design concept is continued from the Jane. I had thought about adopting the "top casing over the bottom of the case" feature which can easily resolve the issue about top-bottom gap, sharp edges, and uneven anodizing issue; but that seemed to make the board look less elegant. In my opinion, the old way is the best way.
Supported layouts:
Material
Alcoa Mic 6 or Kobelco 5052
Reason behind the new material is consistency in quality of the aluminium and to avoid impurities.
In order to minimize the gap between the top and bottom parts, the edges have to be sharp. Strong sandblasting will introduce a small radius to the edges and make the gap obvious. I will be using a milder sandblasting with chemical etching technique to minimise the case gap. This technique requires extra effort for perfect machining/handling and prevention of oxidation during pre-anodising process etc.
The finishing that I am trying to achieve for the TGR-910 will be a lot like Lynn's older boards (ie Dolphin, Whale, and EM7). The quality of the finishing depends a lot of the quality of the raw material, this new material will be the best for the kind of finishing that satisfy my strict requirement.
PCB
I have gotten the permission from Winkeyless' Hojin to design my own PCB with their firmware and GUI. With the help of Leeku and Quadcube, a PCB was specially designed for 910.
Color
- Black, silver and grey
- Pink or Cyan (?)
Price
300$ to 350$
Potato
- There's a small piece of diffuser underneath the logo. Had it tested, I am still not blind.
- Will use a less thick diffuser (1.5mm perhaps)
- The board looks so much more classy without the side diffuser
All the failed prototypes
There are more. 12 units iinm. I will need to fix them and sell to cover back the cost sigh
« Last Edit: Tue, 15 November 2016, 12:22:46 by yuktsi »
email: yuktsi@ttggrr.cc
My collection
Poker 2 | LZ CE | Leopold FC700R | KMAC 1.2 | EXE | GON NS87 | GON Nerd TKL | Duck Poker | Duck Orion | Realforce 87u 55g | OTD 456GT | LZ B7 | OTD 360C | Ducky G2 Pro | Apple Extended | Apple M0116 | Apple M0116 | Cherry G80-1220HAD | Duck Octagon | HHKB Pro 2 | Duck Unicorn | LZ B8 | LZ RE | ENVKX | OTD 456GT | LZ FE | HHKB Type S | TX1800| Duck Orion V2 | LZ FE | KPad | KMAC Happy | ENVKX | LZ RV | KMAC 2 | Whale | Dolphin | EM7 | TGR Jane | VE.A | DK Saver | Matrix 10xv1.0 | Whale | HHKB BT | Dolphin v2 | EM7 v2 | SSK | SSK (Blue Label) | LZ SQ | Duck Octagon v2 | TX84 | GON Mobik | TX-CP | LZ Ergo2 | KMAC Happy HHKB | TGR 910 | TGR Tris | Matrix 8xv1.2 | KMAC Mini | Mira | Fjell | 356mini | Dolphin GH | EM7 GH | TARO EXENT | Masterkey Pro L Crysta l OTD Koala | Duck Viper | Keycult no.1 | 356mini | 356pad | Matrix 8xv2.0 | 420cl | Matrix 8xv1.0 | Whale Special | Poly Dolphin | Keycult No.2 | FMJ80 | Singa R2 | Whale Poly | 356cl | HBCP | Dolinger | Linger | FMJ80 | KFE
Offline yuktsi
Re: [IC] TGR-910 65% masterrace
« Reply #1 on: Fri, 11 November 2016, 08:26:43 »
blocker or no blockers?
cyan or pink?
Tris or no tris?
« Last Edit: Tue, 15 November 2016, 08:43:59 by yuktsi »
My collection
Offline dgneo
  • Supervillain
« Reply #2 on: Fri, 11 November 2016, 08:29:35 »
Hot damn yuktsi, this looks amazing!
Offline FrostyToast
  • Litshoard
« Reply #3 on: Fri, 11 November 2016, 08:30:15 »
Not sure if I like the blocker
Cyan always tho.
Quote from: elton5354
Offline wodan
« Reply #4 on: Fri, 11 November 2016, 08:35:04 »
HELL YEAH Count me in!
Blocker: YES
Color: CYAN
Offline CornCha0s
« Reply #5 on: Fri, 11 November 2016, 08:45:51 »
I'm in! This looks amazing!
Offline yuktsi
« Reply #6 on: Fri, 11 November 2016, 08:46:53 »
Guys, regarding the layout. My LZ SQ has a split spacebar, I've been using 1.25x as spacebar for awhile (better feeling don't have the worry about the stab tuning)
Definitely more dope than conventional 6.25 or 7x and will be offered in 910.
I will update more tmr, supported layout and all. GON Mobik just arrived today and I want to build it.  :p
My collection
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #7 on: Fri, 11 November 2016, 08:48:59 »
I will be buying this for sure.
And pink is my preference. Love the blockers as well  :thumb:
« Last Edit: Fri, 11 November 2016, 08:50:55 by DudeSnail »
Offline oatsbagotes
« Reply #8 on: Fri, 11 November 2016, 08:51:21 »
Interested, very nice board, I also think it looks better without the diffuser :thumb:
Offline yuktsi
« Reply #9 on: Fri, 11 November 2016, 08:58:58 »
Agree.  :thumb:
My collection
Offline catweewee
  • SINGA | singakbd.com
  • Yellows
« Reply #10 on: Fri, 11 November 2016, 09:11:50 »
FINALLY!
Offline devbryce
« Reply #11 on: Fri, 11 November 2016, 09:24:50 »
Looks fantastic, I'm a little bummed about losing the top right key, but I must say it certainly is unique!
65% Life | Neutrino | WhiteFox | TADA68 | RS68
Offline alienman82
« Reply #12 on: Fri, 11 November 2016, 09:25:25 »
removed.
« Last Edit: Thu, 01 March 2018, 13:41:58 by alienman82 »
« Reply #13 on: Fri, 11 November 2016, 09:33:30 »
what's the story behind the name 910?
A random girl he met at a cafe.
Offline kiwi99
  • that's a gnarly dookie
« Reply #14 on: Fri, 11 November 2016, 09:49:50 »
Looks amazing! Never cease to amaze with new elegant designs!
Offline Jokrik
« Reply #15 on: Fri, 11 November 2016, 10:00:56 »
Offline Slash Emperor
  • Lust for life lost, keyboards acquired.
« Reply #16 on: Fri, 11 November 2016, 10:10:12 »
Damn, I love that. I love that 65% life and seeing all these awesome 65% boards coming out now makes me a very happy camper.
I'd love to pick up one of these and feel the TGR quality for myself.
Yes to blocker. I could go either, but I'd prefer cyan. Though I love that purple for the prototype even more.
« Last Edit: Fri, 11 November 2016, 10:28:03 by Slash Emperor »
Offline redbanshee
  • actually Dade Murphy
« Reply #17 on: Fri, 11 November 2016, 10:12:52 »
I thought I didnt like the blocker on the bottom row then I realized that it actually sets this apart from others and looks really good! I like it!
Offline Nafs_asp
« Reply #18 on: Fri, 11 November 2016, 10:13:38 »
I'm a big fan of the bottom row layout with the single 1.5u on the right and a spacer between it and the arrows
Offline RocketGruntJake
  • Brb, gotta grow some flowers
« Reply #19 on: Fri, 11 November 2016, 10:16:09 »
I'd be so in for one of these.
I like the blocker, gives a more unique look.
Out of the two I'd say cyan.
Offline cmd
« Reply #20 on: Fri, 11 November 2016, 10:23:33 »
 :thumb: :thumb: :thumb: :thumb:
Offline Blackhawk
« Reply #21 on: Fri, 11 November 2016, 10:30:10 »
Not a fan of the blockers, but the design is perfect.  :thumb:
Offline pr0ximity
« Reply #22 on: Fri, 11 November 2016, 10:31:28 »
Neat keyboard
Offline Moistgun
  • Slippery When Wet
« Reply #23 on: Fri, 11 November 2016, 10:33:19 »
I would like this more if the TGR and 910 swapped places I think.
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #24 on: Fri, 11 November 2016, 10:44:02 »
This + my GMK Black lotus! :D
Offline rotciveel
  • Fugu Curator Extraordinaire
« Reply #25 on: Fri, 11 November 2016, 10:52:10 »
i like blocker and side diffuser! looks niceeee
Offline polentA
  • Formerly withoutrulers
  • GMK plz
« Reply #26 on: Fri, 11 November 2016, 10:59:03 »
This is awesome. Would love to support this.
Offline IneffableTao
« Reply #27 on: Fri, 11 November 2016, 11:08:00 »
I'm a big fan of the diffuser and both blockers, though I would be fine with or without the top right one.  Blocker between arrows and modifiers is a favorite for me, helps to find the arrows that much easier.
Will there be options to purchase additional pieces to either swap plate/pcb or use a diffuser/not?
Offline menuhin
« Reply #28 on: Fri, 11 November 2016, 11:14:16 »
Is it a pink case?
It goes really well the with GMK Skeletor's purple.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #29 on: Fri, 11 November 2016, 11:28:21 »
Agreed :)
Also, I'd assume you could still light up the logo without case diffuser?
Since I also prefer that cleaner look but like the logo.
This looks great, haven't been interested in an MX board for awhile :thumb:
Offline Kominyetska
« Reply #30 on: Fri, 11 November 2016, 11:36:03 »
I want one of these to put the Otaku keyset on. That would be a super sexy travel board.
Offline catweewee
  • Yellows
« Reply #31 on: Fri, 11 November 2016, 11:53:06 »
Aluminium travel board?
Offline Kominyetska
« Reply #32 on: Fri, 11 November 2016, 12:03:24 »
Sure, why not? I'm traveling in a car mostly, so it's not like weight is a problem.
« Reply #33 on: Fri, 11 November 2016, 12:10:34 »
Teach me your ways.
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #34 on: Fri, 11 November 2016, 12:11:23 »
That side profile shot with the diffuser - sublime.
Offline PerniciousPony
« Reply #35 on: Fri, 11 November 2016, 12:23:18 »
That blocker is amazing, really makes the board stand out from the wave of 65% boards hitting the market.  I'd also prefer pink over cyan  :thumb:
Offline redbanshee
« Reply #36 on: Fri, 11 November 2016, 12:45:28 »
Going to agree with the others that have said that swapping the TGR and 910 logos would look better!
Offline ntw
« Reply #37 on: Fri, 11 November 2016, 13:24:18 »
I think the TGR logo needs to be slightly higher up.  :thumb:
Offline ReverbSlush
  • 16/52 RNG score
« Reply #38 on: Fri, 11 November 2016, 13:29:08 »
love the blocker. watching this thread!
Offline doom2
« Reply #39 on: Fri, 11 November 2016, 14:46:07 »
Love it!
Offline liftylol
« Reply #40 on: Fri, 11 November 2016, 14:58:12 »
Looks very nice and incredibly clean, definately interested! But i would really love the purple as a color to pick and ive already seen a few comments on reddit about that so if you could offer a purple id be in for sure :
Offline oatmicro
« Reply #41 on: Fri, 11 November 2016, 15:01:43 »
love the blocker.
and Pls Cyan if possible
Offline HappyCatFish
« Reply #42 on: Fri, 11 November 2016, 15:02:02 »
I'm not a huge fan of the gap between the arrow keys and the right Alt but overall its a very sexy board.
Great work again! As usual.
Offline ticktwo
  • -kbdfan
« Reply #43 on: Fri, 11 November 2016, 16:39:09 »
interested!  :eek:
HHKB | Leopold FC750R | Mech27 (soon) | TX-75 (soon)
Offline MaNiFeX
  • Wu Tang Killa Keebs
    • MaNiFeX.net
« Reply #44 on: Fri, 11 November 2016, 17:06:38 »
Definitely in!  Missing the corner key, but it also makes the board unique.   :thumb:
Offline raymogi
« Reply #45 on: Fri, 11 November 2016, 19:08:17 »
Yes please.
Please feed my addiction.
Offline duhhey
« Reply #46 on: Fri, 11 November 2016, 20:32:14 »
So beauty. I want pls
Offline DanB
« Reply #47 on: Fri, 11 November 2016, 21:49:39 »
Cyan with blockers is my preference, count me in.
IMO, I would like to have the option for diffusers.
« Last Edit: Fri, 11 November 2016, 21:56:29 by DanB »
Kingsaver, Koala
Offline effectiveduck
« Reply #48 on: Fri, 11 November 2016, 22:18:43 »
Glad to see this is finally moving forward, been looking forward to this for a while.
For me the top right corner block kinda ruins the design, probably enough for me to skip this so the option to remove it would be very welcomed. I love the bottom row block though, it can accomodate a few other cool layouts like 1.25 1.25 1.25 6.25 1.25 1.25 and 1.5 1 1.5 6 1.5 1.5, if the plate fits them. TGR logo placement seems a bit off, maybe its too low, not exactly sure.
Offline lildragonbuns
  • Formerly ilovekeycaps
« Reply #49 on: Sat, 12 November 2016, 12:47:29 »
This is the sexiest board I have seen in so long. I'm definitely joining this  :thumb: :thumb: :thumb: :thumb:
