Advanced search
it's a keyboard thing
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Have you read the
geekhack TOS
lately?
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Projects
Making Stuff Together!
(Moderator:
Soarer
Question: Bluetooth (Bluefruit EZ e.g.) adapter
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Question: Bluetooth (Bluefruit EZ e.g.) adapter (Read 3993 times)
Phenix
Thread Starter
on:
Fri, 11 November 2016, 09:13:03 »
Hi
I would like to add bluetooth to my keyboards.
So I was thinking about some kind of adapter, basically:
Box in which batterys+hardware sits
one port for charging
two plugs (micro and mini USB
Is there some kind of guide for doing this? I only find guides for the Planck, but I cant really think of how to wire it properly.
charger:
https://www.adafruit.com/products/259
an battery:
https://www.adafruit.com/products/258
bluefruit EZ
https://www.adafruit.com/product/1535
Logged
Winter is coming.
redbanshee
actually Dade Murphy
Re: Question: Bluetooth (Bluefruit EZ e.g.) adapter
Reply #1 on:
Fri, 11 November 2016, 09:55:01 »
I use the Bluefruit EZ for a HTPC controller in my living room. But it is only 8 keys, I think you need to use the combination of the bluefruit EZ and a Pro Micro to get it to do more then 12 keys. It works really well for my uses though!
just saw this
https://geekhack.org/index.php?topic=50183.0
Logged
Phenix
Thread Starter
Reply #2 on:
Fri, 11 November 2016, 12:02:53 »
Thanks for that link!
I am either using an xwhatsit (Model F) or an QMK based board.
So do you think i need another teensy in the bluetooth box?
(I am still confused if/how to do.)
Logged
Winter is coming.
redbanshee
Reply #3 on:
Fri, 11 November 2016, 12:05:43 »
You have to use the Pro Micro to send the info to the Bluefruit EZ and then then EZ translates those commands and sends them to the PC over bluetooth.
I know thats how its done but I personally have not done it or researched it beyond watching the videos on the Adafruit site, and i think they mention it in on of those videos.
Logged
Phenix
Thread Starter
Reply #4 on:
Fri, 11 November 2016, 12:19:51 »
Well - so it goes like
keyboard (where QMK is used)
plugs into
pro micro
connected to
bluefruit EZ
connected to the charging port
Logged
Winter is coming.
feralfoo
Software developer and mech keyboard nut
Reply #5 on:
Fri, 11 November 2016, 19:58:22 »
There is also the
Adafruit Feather 32u4 Bluefruit LE
https://www.adafruit.com/products/2829
. It has usb port, lipo battery power and charger, bluetooth and an atmega32u4. The CPU is overkill and it only has one usb port, but may prove more convenient as its a tiny all in one solution.
Logged
HHKB Pro JP + Hasu controller, Realforce RF87U55G, G60 Retro, QK65
Phenix
Thread Starter
Reply #6 on:
Thu, 17 November 2016, 15:25:39 »
it is clocked at 8mhz,
in an other thread (also with bluetooth/MCU, cant find it atm) one mentions QMK runs at 16mhz - sure it will work?
Badly I cant do much programming, so I need pretty basic/easy to do things..
Logged
Winter is coming.
lucidinertia
Reply #7 on:
Fri, 18 November 2016, 14:52:15 »
I may be in a similar boat. I have signed up for Xmit's 104-key hall effect drop. I use a Filco Majestouch Convertible 2 and love it as a HTPC and portable keyboard between stations. I would love to enable that same kind of functionality, inside the board itself or with minimal modifications.
Logged
Print
Pages: [
1
Go Up
« previous
next »
geekhack
geekhack Projects
(Moderator:
Soarer
