Author Topic: casting questions  (Read 2949 times)
Offline kolec94
casting questions
« on: Mon, 14 November 2016, 11:43:40 »
i am wanting to get into casting keycaps and beads and i was wondering what i should get i would like to have ability to do metal to if it not to much to ask
kbparadise v60 blues
Offline redbanshee
  • actually Dade Murphy
Re: casting questions
« Reply #1 on: Mon, 14 November 2016, 11:50:39 »
You would need a metal crucible and silicone that will withstand metal temperatures like smooth-on mold max 60
Offline kolec94
« Reply #2 on: Mon, 14 November 2016, 11:58:39 »
other option i need something that can with stand 1100C
« Reply #3 on: Mon, 14 November 2016, 15:20:17 »
Yeah, no. Metal casting requires significantly more than that.
OP, if you are not willing to do the research, you should not be doing metal casting.  Metal casting poses significant risk of injury if you do something wrong.  If you're fine with low resolution casting, look into sand casting.
Offline kolec94
« Reply #4 on: Mon, 14 November 2016, 15:59:26 »
I have done some research and found investment for a single mold but I don't like the process of making it and the fact it's one time use
Sent from my XT1526 using Tapatalk
« Reply #5 on: Mon, 14 November 2016, 16:13:24 »
Investment casting is the only realistic home casting process if you want decent to good fidelity.
« Last Edit: Mon, 14 November 2016, 16:26:06 by nubbinator »
Offline kolec94
« Reply #6 on: Mon, 14 November 2016, 18:19:17 »
is there any way of getting multiple runs from the same investment?
