Author Topic: Issues with KBP V60 with Gat Blacks and aftermarket cases  (Read 2129 times)
Offline CapnHighlands
« on: Mon, 14 November 2016, 20:02:32 »
I recently bought a KBP V60 with Gat Blacks (which are now my favorite switch of all time) and a Royal Glam case. However, the Royal Glam case didn't work (there is no way to screw the top part of the board down for whatever reason) and so now I'm looking at other cases. What are some confirmed cases that work with the Gateron version of the V60? I'm looking at Tex cases specially (but I know some of them don't work).
Offline Tactile
Re: Issues with KBP V60 with Gat Blacks and aftermarket cases
« Reply #1 on: Mon, 14 November 2016, 21:26:07 »
What is the "top part of the board"?
REΛLFORCE
Offline pixelpusher
« Reply #2 on: Mon, 14 November 2016, 21:50:35 »
I have the v60 with Matias switches.  It only allows for 3 screws to fasten to the royal glam (i have the wrist rest version that didn't come with standoffs)... left, right and just to the right of the space bar.
I got mine to work with the wrist rest version by
a.) getting a chisel and deepening and lengthening the DIP switch recessed circle and
b.) adding some spacers where the screw holes were in the case (mine didn't come with any standoffs and no passthrough hole for changing the DIP switches).  For spacers, I bought some #6 brass nuts (about 4mm tall) and used adhesive to glue them right over the built-in screw holes.  They do sell 4mm standoffs for M2 screws, but the shipping was going to take 2 weeks and I'm impatient.
Then, on the reverse at the top of the board and in the mid section, I got some craft foam pads and added them (a few layers, to build up height) so that when I tightened the 3 screws the top of the board was firm against the case.  I had to experiment.  Too much foam and it will feel smushy when you hammer the top row, and will probably have a slight bulge in the middle when viewed straight on from the rear.  But once I got the height right it worked great!  I'm pretty picky too.
I also know that at least some of the TEX cases will work.  I have the frosted acrylic version and I put my v60 in it for a test fit.  The USB plug is incredibly close to not working, but it will work.  Luckily, you won't have the support issues at the top like in the royal glam  b/c the tex cases have fins in them that are the same height as the screw posts, and they support it great.
The frosted case has a larger front bezel, and so I'm pretty sure any of the ones that share it's form factor will definitely work for the v60.  I really love the TEX case.  I just wish it was about $20 cheaper.  Also, the included taller 3M rubber feet for it look cheap.  Just don't look under there :)
You know, when I was modding that case I kept telling myself that I really needed to take some photos for others but I didn't.  It's such a pain in the ass to remove those Alps stabilizers to get it back off though... maybe one of these days.
« Last Edit: Mon, 14 November 2016, 21:53:56 by reececonrad »
Offline Rainman
« Reply #3 on: Tue, 15 November 2016, 07:47:16 »
May I ask where did you buy your kbp v60 from? I'm looking to buy it from keyboardco.com (I'm in Europe) but I'm afraid they have the old batch which do not support aftermarket case.. I already have a Pok3r and I want to use its case for the kbp v60.
Rocking Poker 2 with vintage MX Blacks
Offline pixelpusher
« Reply #4 on: Tue, 15 November 2016, 08:20:40 »
I honestly don't know where it originally came from because I bought it used off of ebay.  Sorry :(
Offline Rainman
« Reply #5 on: Tue, 15 November 2016, 11:05:43 »
How long has it been since you own it? The seller at a keyboard store told me the keyboards they're selling are from a batch that came in their store like 5-6 months ago.
Offline pixelpusher
« Reply #6 on: Tue, 15 November 2016, 12:09:54 »
I bought it on Aug 31st.  The previous owner said he had owned it for 3 weeks.
