Author Topic: Cannot one get the 5th column on my handwired Planck to work (Teensy 2++, TMK)  (Read 2888 times)
Offline cygnusx1_
Hello folks!
I've handwired my third board, a simple grid layout Planck. However, I cannot seem to get the 5th column, the 'R' column, to work, no matter the pin I use on the Teensy 2++ that I have it wired up to.
I built the firmware by starting with the handwired blank Python script for the AVR Firmware generator. Everything else works but that row; I know it's not shorted, or wired improperly; I went through it with a multimeter and everything looks peachy. However, I'm inclined to believe that it is an error in my code, despite labeling the correct configuration for column/row pinouts.
I will post my code tomorrow if needed (since I'm not at my work laptop, where it is stored), but I think this boils down to a problem with how I'm programming things and the fact that I am using a Teensy 2++ rather than the usual Teensy 2.
Thanks for any help or suggestions!
Offline cygnusx1_
Here is the Python code for the column/row identification:
Code: [Select]
matrix_hardware, matrix_strobe, matrix_sense = make_matrix_config(
    strobe_cols=strobe_cols,
    strobe_low=strobe_low,
    rows=[D4, D5, D7, D2],
    cols=[F2, F3, F4, F5, C0, F7, C1, C2, C3, C4, C6, C7],
    device=firmware.device
If I move the position of the 5th column (C0), I find that the columns shift, but regardless, that fifth column never works. The switch works, the wiring is correct, and there are no shorts. I went through it thoroughly with a multimeter. Any advice?
I'm no tmk expert but that little bit of python looks more like an easyavr config file?
Whatever it is please can you post the whole of any config file(s) you changed as your problem is not in that bit :)
Offline cygnusx1_
You're correct! I can't get TMK working, but I can get easyavr partially working so I stuck with that. Here is the full code (with just the base layer for debugging):
Code: [Select]
# Easy AVR USB Keyboard Firmware Keymapper
# Copyright (C) 2013-2016 David Howland
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License along
# with this program.  If not, see <http://www.gnu.org/licenses/>.
"""Keyboard definition for a hand-wired keyboard"""
# The first decision you have to make is to choose a hardware
# layout.  Assuming you are using a Teensy2.0, ATmega32U4_16MHz_TKL
# is probably the best hardware layout for you.  ATmega32U4_16MHz_SIXTY
# might also work for you, though.  The sizes are defined in the
# templates/__init__.py file of the keymapper.
# Leave the rest of the imports like they are here.
import easykeymap.templates.AT90USB1286_16MHz_COSTAR as firmware
from easykeymap.ioports import *
from easykeymap.helper import make_matrix_config
# The name of the board in the "New" dialog
description = "Kam's Planck"
# Unique string to identify THIS exact hardware layout
unique_id = "HANDWIRE_001"
# The name of the .cfg file the system will try to find for altered
# layout options.  See the configs subdir of the keymapper.
cfg_name = "handwire"
# Hand-wired boards usually use Teensy controllers.  Set this to
# True to make sure that the bootloader works.
teensy = True
# If your board has an exposed switch for going into the bootloader,
# you can set this to True and the system won't prompt you to add a
# BOOT key to your layout.
hw_boot_key = False
# These two parameters define the size of the keyboard in the display.
# Must be whole numbers in units of quarter key lengths.  A TKL
# usually is 6 rows high with a 1/2 key length gutter under the Fn row.
# Therefore int(6.5*4).  Apply the same logic the width.  Remember
# we are talking visual width, not number of columns.
display_height = int(4*4)
display_width = int(12*4)
# The number of rows and columns in the matrix.  In a hand-wired board
# each of these will correspond to a single pin.
num_rows = 4
num_cols = 12
# Keyboards work by scanning a matrix to check each key.  The scan
# works by setting an active row/column (strobing) and then reading
# the status of every switch that crosses it (sensing).
# strobe_cols tells the firmware which direction you have your diodes
# installed.  If diodes go from column to row, then strobe_cols must
# be False.  If diodes go from row to column, then strobe_cols must be
# True.
strobe_cols = False
# strobe_low tells the firmware if a row/column should be activated
# by pulling the pin high or low.  Hand-wired boards will almost always
# use strobe_low = True
strobe_low = True
# The matrix_hardware, matrix_strobe, matrix_sense parameters tell
# the firmware how to initialize the ports, what pins must be set
# for each row/column, and what order to strobe/sense.  These are
# complicated and are explained fully elsewhere.  It is easiest to
# configure the matrix by using the make_matrix_config function as
# shown below.  Just customize 'rows' and 'cols' for your project.
    cols=[C0, F2, F3, F4, F5, F7, C1, C2, C3, C4, C6, C7],
# The total number of LED outputs (indicators + backlights)
num_leds = 0
# The number of LED indicators (for example, caps lock)
num_ind = 0
# The number of backlight enable modes.  This counts the number of
# options available for the BL_ENABLE key.  Boards without backlights
# should use the minimum value of 2.
num_bl_enab = 2
# Define the default assignments of the indicator LEDs.  The length
# of this list must equal num_ind.  For each LED, the first string
# is the description of the key shown in the GUI.  The second string
# is the default function assigned to that LED.  LED functions must
# be strings as defined in led_assignments of gui.py.  Common choices
# are 'Num Lock', 'Caps Lock', 'Scroll Lock', 'Win Lock', 'Fn Active',
# 'Recording', 'Backlight', and 'Unassigned'.
led_definition = [
# Definition of LED pins.  (indicators and backlights)  Indicators
# must come first and be in the same order as defined in led_definition.
# LED_DRIVER_PULLUP is used when the pin is connected to the anode of
# the LED and the cathode is connected to ground.
# LED_DRIVER_PULLDOWN is used when the pin is connected to the cathode
# of the LED and the anode is connected to the power supply.
led_hardware = [
# True if the board supports backlight, otherwise False
backlighting = False
# This can be used to configure different backlighting zones.  Explained
# in more detail elsewhere.  Length of list must equal num_bl_enab.
# Length of each tuple must equal num_leds.  Tuples use the same ordering
# as led_hardware.  Almost everyone should just use an all-on/all-off
# configuration.  That's a list of two tuples, one with all 1s for each
# LED, the other with all 0s for each LED.
bl_modes = [
# Just leave this here as-is.
KMAC_key = None
# Define your layout.  This is a list of rows.  Each row is a list
# of keys.  Each key is a tuple of three items.  First item is a tuple
# defining the width,height of the key.  If it is just a number, it
# will be a space instead of a key.  All units are in quarter key lengths,
# so a standard key would be (4,4).  Second item is a tuple defining the
# row,column in the matrix for that key.  Third item is the default scancode
# for that key, from scancodes.py.  If a row is a number instead of a list,
# it will just make a vertical spacer.
keyboard_definition = [
    [((4, 4), (0, 0), 'HID_KEYBOARD_SC_ESCAPE'),
     ((4, 4), (0, 1), 'HID_KEYBOARD_SC_Q'),
     ((4, 4), (0, 2), 'HID_KEYBOARD_SC_W'),
     ((4, 4), (0, 3), 'HID_KEYBOARD_SC_E'),
     ((4, 4), (0, 4), 'HID_KEYBOARD_SC_R'),
     ((4, 4), (0, 5), 'HID_KEYBOARD_SC_T'),
     ((4, 4), (0, 6), 'HID_KEYBOARD_SC_Y'),
     ((4, 4), (0, 7), 'HID_KEYBOARD_SC_U'),
     ((4, 4), (0, 8), 'HID_KEYBOARD_SC_I'),
     ((4, 4), (0, 9), 'HID_KEYBOARD_SC_O'),
     ((4, 4), (0, 10), 'HID_KEYBOARD_SC_P'),
     ((4, 4), (0, 11), 'HID_KEYBOARD_SC_BACKSPACE')],
    [((4, 4), (1, 0), 'HID_KEYBOARD_SC_TAB'),
     ((4, 4), (1, 1), 'HID_KEYBOARD_SC_A'),
     ((4, 4), (1, 2), 'HID_KEYBOARD_SC_S'),
     ((4, 4), (1, 3), 'HID_KEYBOARD_SC_D'),
     ((4, 4), (1, 4), 'HID_KEYBOARD_SC_F'),
     ((4, 4), (1, 5), 'HID_KEYBOARD_SC_G'),
     ((4, 4), (1, 6), 'HID_KEYBOARD_SC_H'),
     ((4, 4), (1, 7), 'HID_KEYBOARD_SC_J'),
     ((4, 4), (1, 8), 'HID_KEYBOARD_SC_K'),
     ((4, 4), (1, 9), 'HID_KEYBOARD_SC_L'),
     ((4, 4), (1, 10), 'HID_KEYBOARD_SC_SEMICOLON_AND_COLON'),
     ((4, 4), (1, 11), 'HID_KEYBOARD_SC_APOSTROPHE_AND_QUOTE')],
    [((4, 4), (2, 0), 'HID_KEYBOARD_SC_LEFT_SHIFT'),
     ((4, 4), (2, 1), 'HID_KEYBOARD_SC_Z'),
     ((4, 4), (2, 2), 'HID_KEYBOARD_SC_X'),
     ((4, 4), (2, 3), 'HID_KEYBOARD_SC_C'),
     ((4, 4), (2, 4), 'HID_KEYBOARD_SC_V'),
     ((4, 4), (2, 5), 'HID_KEYBOARD_SC_B'),
     ((4, 4), (2, 6), 'HID_KEYBOARD_SC_N'),
     ((4, 4), (2, 7), 'HID_KEYBOARD_SC_M'),
     ((4, 4), (2, 8), 'HID_KEYBOARD_SC_COMMA_AND_LESS_THAN_SIGN'),
     ((4, 4), (2, 9), 'HID_KEYBOARD_SC_DOT_AND_GREATER_THAN_SIGN'),
     ((4, 4), (2, 10), 'HID_KEYBOARD_SC_SLASH_AND_QUESTION_MARK'),
     ((4, 4), (2, 11), 'HID_KEYBOARD_SC_ENTER')],
    [((4, 4), (3, 0), 'HID_KEYBOARD_SC_LEFT_CONTROL'),
     ((4, 4), (3, 1), 'HID_KEYBOARD_SC_LEFT_GUI'),
     ((4, 4), (3, 2), 'HID_KEYBOARD_SC_LEFT_ALT'),
     ((4, 4), (3, 3), 'HID_KEYBOARD_SC_RIGHT_SHIFT'),
     ((4, 4), (3, 4), 'SCANCODE_FN'),
     ((4, 4), (3, 5), 'HID_KEYBOARD_SC_SPACE'),
     ((4, 4), (3, 6), 'HID_KEYBOARD_SC_SPACE'),
     ((4, 4), (3, 7), 'SCANCODE_FN2'),
     ((4, 4), (3, 8), 'HID_KEYBOARD_SC_LEFT_ARROW'),
     ((4, 4), (3, 9), 'HID_KEYBOARD_SC_DOWN_ARROW'),
     ((4, 4), (3, 10), 'HID_KEYBOARD_SC_UP_ARROW'),
     ((4, 4), (3, 11), 'HID_KEYBOARD_SC_RIGHT_ARROW')]
alt_layouts = {}
Excellent!
That config file looks perfect so I'll guess the problem is choosing COSTAR for the firmware - the Costar build has a lot of rows and columns while your board is most definitely a rectangle, so FULLSIZE would be more appropriate (SIXTY really, but there isn't one for the ++)  It is a bit strange that it drops one out of the middle not the end, but why not...
If it's not that it would have to be a hardware problem - if you're sure the wiring is good perhaps a metal case causing a short?
You could also try shorting the row pin to column pin on the Teensy to simulate keypresses, it's no different than pressing a switch so no damage will be done.  This would confirm the Teensy and firmware are fully functional and that the problem is elsewhere.
Offline cygnusx1_
Thanks for the tips! I tried what you recommended and shorted the column with it's row only have the key start spamming R like crazy until I unplugged it. I'm not sure what that could be, but I'm going to investigate for any mysterious shorts because this is strange,
EDIT: I fixed it! I desoldered the entire column and wired it up with some fresh stuff, and boom, now it works. Thanks for your help!
« Last Edit: Sun, 20 November 2016, 14:00:01 by cygnusx1_ »
Didn't see the edit, glad to hear you got it working - don't forget to post pics!
