Author Topic: Is -5v in a computer PSU still used?  (Read 4661 times)
« on: Sat, 19 November 2016, 09:07:52 »
Carrying on from yesterday's hard drive fun I have filled every phone, memory card and old hard drive in the house with files, got most of them.  The computer crashed overnight while zero filling so there is a problem.
Found a PSU tester and all the lights are green except -5v, which of course is impossible to google anything about!  Anyone know if this is still used?  It's always been pathetic so might have been phased out, I hope.
« Last Edit: Sat, 19 November 2016, 09:30:31 by suicidal_orange »
Offline nugglets
Re: Is -5v in a computer PSU still used?
« Reply #1 on: Sat, 19 November 2016, 10:43:57 »
https://www.lifewire.com/atx-24-pin-12v-power-supply-pinout-2624578
Only used in 20pin atx connectors, but still supported on some modern PSUs to maintain compatibility with older hardware.
edit - Pinout comparison:
« Last Edit: Sat, 19 November 2016, 10:49:58 by nugglets »
« Reply #2 on: Sat, 19 November 2016, 10:51:49 »
Thanks, didn't think of looking for a pinout :thumb:
I don't really want to spend money on a new PSU only to wait until Tuesday for it to be delivered then find it doesn't help - life was so much easier when you could just swap parts with a friend but the world's gone laptop mad...
Offline nugglets
« Reply #3 on: Sat, 19 November 2016, 10:58:08 »
I know that feeling... Thankfully I have a graveyard of parts in the garage for these occassions.. or so I tell myself. The reality is I'm mostly just too lazy to lug it all to the recycler.
That said, I remembered learning about the -5v change from 20 to 24 pin but couldn't remember what it was actually used for. Because I know you can use a 24pin connecter in a 20pin mobo without issues these days, it got me wondering. Just looked it up and it was only used for ISA bus... so it has been obsolete for a very, very long time.
Not that any of this information really helps you, but the more you know right? =)
Good luck!
« Reply #4 on: Sat, 19 November 2016, 11:08:02 »
Haha, ISA... that was a while ago.
My parts bin is useless as this is only my second 24pin PSU and the first I gifted to a friend when he bought a mobo, CPU and RAM because I suspected it was dodgy, but he ran it for a couple of years before it died.  Then he got a laptop.
I'm waiting for a crash with a drive related sound, 8.33 hours to fill a slow and quiet 3tb drive so I think caffeine would be more useful than luck but thanks anyway!
Offline soilheart
« Reply #5 on: Sat, 19 November 2016, 14:19:06 »
Oh, I replaced a PSU without a -5v pin with a new one with a -5v pin the other week (had to look it up what the extra pin was to make sure that it wouldn't cause any issues ;) ).
I assumed it was used by serial bus:es, but I just realized that (the actual) RS232 standard calls for 12v to -12v... and that pin is still around so clearly my assumption was wrong.
On a related note, my father used an ISA soundcard for a long time, as he found it much better than the built-in ones. I think he finally had to give it up when he bought a new computer a year ago (which have no extra extension card slots whatsoever =P).
(K70 -  Brown) --- Pok3r - Clear --- Ducky Shine4 - Clear --- WKL B.face X2 - 67g Zealios --- CP-SQ - 78g Zealios --- RS68 - 62g Zealios
(Sold/retired - To be built)
« Reply #6 on: Sat, 19 November 2016, 19:43:53 »
9.5 hours into my theoretical 8.33, some strange messages about USB but still seems to be writing to the dodgy drive, if I weren't soaked with rain I'd call it a night but soggy hair doesn't make for a good sleep...
PCI soundcards have been around for many years and surely there are PCI-E ones these days - I agree there are improvements over onboard, I've used a USB DAC for years :)
Offline 0100010
  • Not Sure
« Reply #7 on: Sat, 26 November 2016, 22:59:24 »
I've got a "benchtop power supply" made from an old ATX PSU and adapter board, but not old enough that it still supplied -5VDC, so that location on the board doesn't have a post mounted.
