Author Topic: Model F, 122 key, 3179 Terminal  (Read 4716 times)
Offline ch_123
« on: Sat, 23 January 2010, 09:29:23 »
Link
No pics unfortunately. Features determined by part number.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #1 on: Sun, 24 January 2010, 10:07:27 »
I've got my eyes on that one. I've always wanted a Model F so I could see how they feel.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #2 on: Sun, 24 January 2010, 10:24:58 »
Quote from: microsoft windows;153394
Model M 122-key terminal keyboards are NOT an accurate gauge of how a 101-key Model M feels (though keep in mind that's a 1986/1989 comparison), so it's probably worth noting that a Model F 122-key terminal keyboard might not be an accurate gauge of how an AT Model F feels.
kishy.ca
« Reply #3 on: Mon, 25 January 2010, 15:39:39 »
Quote from: kishy;153403
Well, it depends mostly on the wear it's gotten. But it has the same type of switch as an AT so it's got to be at least close. And Model F's also don't have those rivets which are prone to breakage that Model M's have.
« Last Edit: Mon, 25 January 2010, 15:41:41 by microsoft windows »
Offline ch_123
« Reply #4 on: Mon, 25 January 2010, 15:46:34 »
Definitely. There's no reason why the terminal keyboards would feel any different aside from age. There is some degree of variance between Model Fs in build quality, but I think the terminal ones are one of the more better built ones.
« Reply #5 on: Mon, 25 January 2010, 15:50:40 »
Quote from: ch_123;153665
I also like the layout of the terminal ones better with their full-size back space key. In addition, I can add extra springs and break up the right Shift, both Enter's, and the Backspace without having to remove all those rivets.
It's also much cheaper and has all its keys intact. With a little work, I should have it up and running with a PS/2 connector thanks to Kishy's guide.
Offline ch_123
« Reply #6 on: Mon, 25 January 2010, 17:14:44 »
I think I had some success getting the "European" key working (i.e. the one between shift and Z). That said, the method I was using to test it may not have worked properly for undefined scan codes. YMMV in regards the other ones.
Offline vils
« Reply #7 on: Mon, 25 January 2010, 17:41:55 »
Quote from: ripster;153692
Hmm..... If I open up the Model F AT and 10 years later still list it on Ebay as NIB will I go to Hell?.........
No, but you will have to bite the head of a chicken and spend a night on Haiti with Pat Robertson.
It\'s the glass pipe fallacy. You can only believe that if you\'re on crack.
Offline ak_nala
« Reply #8 on: Mon, 25 January 2010, 19:13:00 »
Even if they prove to be active on an AT, however, still wouldn't answer whether they are active on the 122-key Model F's.
« Last Edit: Mon, 25 January 2010, 19:15:19 by ak_nala »
No matter where you go, there you are...
« Reply #9 on: Tue, 26 January 2010, 13:18:14 »
Quote from: ripster;153685
I thought CH123 said the extra pads in the Model F are dead?  I tried to poke something down a hole but the pads are offset from the key wells.
Which type of Model F does he have experience with? I think the maps on the 122-key and 84-key variants differ.
But, one must remember that the Model M with the 101-key design was derived from the 122-key Model F. That leads me to believe that their maps are similar, if not identical. But, it will take a real specimen to truly tell.
« Last Edit: Tue, 26 January 2010, 13:23:01 by microsoft windows »
Offline ricercar
  • mostly abides
« Reply #10 on: Tue, 26 January 2010, 13:28:13 »
Quote from: ch_123;153217
Auction has pictures now.
