Author Topic: Picked up a dolch keyboard, what are chances it's cherry?  (Read 6144 times)
Offline bexleycorona
« on: Mon, 21 November 2016, 21:02:55 »
I just picked this up on the auction website and it's from a PAC 65. From what I've read PAC 65 had a transition to sliders. Judging by the depth of the keycaps and colors would this have vintage blues? Any advice is appreciated!
« Last Edit: Mon, 21 November 2016, 21:39:53 by bexleycorona »
GE Marquette | Rosewill RK-9000 | Rosewill Apollo 9100 | Realforce 87U "EK Edition" 45g Uniform | Unicomp Ultra Classic Black Buckling Spring | Realforce 87U SE07T0 Variable | Dolch PAC65
Offline jaffers
Re: Picked up a dolce keyboard, what are chances it's cherry?
« Reply #1 on: Mon, 21 November 2016, 21:05:33 »
100% it's cherry, blues? Don't know, you can't tell from just looking at it, you've got to take a keycap off. Probably has blues, its a dolch after all https://deskthority.net/wiki/Cherry_G80-1813
« Last Edit: Mon, 21 November 2016, 21:08:54 by jaffers »
« Reply #2 on: Mon, 21 November 2016, 21:14:55 »
Unfortunately due to thanksgiving break I won't get it until early December. Guess I'll wait and see what happens.
Offline merlin64
    • MechMerlin
« Reply #3 on: Mon, 21 November 2016, 21:18:43 »
I've got the same one, it's the Cherry vintage blues. The shade of the blue stem is lighter/neon than the current ones.
Offline jaffers
« Reply #4 on: Mon, 21 November 2016, 21:27:16 »
Interesting, are there any other differences in the switches aside from the stem colour? Perhaps slight differences to housing style?
Offline Tangtawan
Re: Picked up a dolch keyboard, what are chances it's cherry?
« Reply #5 on: Tue, 22 November 2016, 03:48:07 »
what are the differences between vintage MX Blues and the one currently in the market.
My boards : Model F AT (6450200), Industrial M (1394950), Model M SSK (1391472), Model M13 (13H6705), Model M (1390131), Focus FK-2001 (ALPS SKCM Blue), HHKB Pro 2, Realforce 87U 55g, KBP V80 Matias Click, TADA68 (Gateron Reds), Filco Majestouch 2 TKL (67g Ergo Clears), Cherry G80-11800 (Ergo Clears), KBT One 108 (MX White), Ducky One TKL RGB (MX Black), Filco Majestouch Tenkeypad (MX Brown), Leopold FC210TP (MX Red)
Offline jerue
  • (Whenever that happens :P)
« Reply #6 on: Tue, 22 November 2016, 08:24:12 »
PAC 65's were a mixed bag, some were the older style and used MX blues and others were the slimmer rubber dome version. Based on the photo above I am positive that is the older MX version, but pull a keycap off to confirm.
To me, vintage mx blues have a slightly smoother feel and the sound of the click is more consistent. I also don't experience the hysteresis problem as much as modern blues, but that could be me.
davkol did an excellent comparison, click here
« Last Edit: Tue, 22 November 2016, 08:26:02 by jerue »
« Reply #7 on: Tue, 22 November 2016, 17:06:55 »
I hated the dolch "vintage" blues, especially with a stainless steel plate installed and replaced them with modern ones. They felt a little "softer" and with more of a muted click.
anyway, really old dolch used cherry black (and had different keycap colour), the really common dolch pac64 and 65 used blue, and modern dolch used either Ml or RD, I forget which. Yours s cherry, just looking at the-shape of the keycaps as has bene said.
« Reply #8 on: Tue, 22 November 2016, 20:29:11 »
Fantastic, I was really worried I might have bought the wrong keyboard.
Offline Ail
  • RIP in Pape
« Reply #9 on: Fri, 25 November 2016, 19:46:38 »
Edit: Not sure how my PM reply ended up on your thread.  :p
« Last Edit: Fri, 25 November 2016, 19:58:07 by Ail »
« Reply #10 on: Fri, 25 November 2016, 20:03:51 »
On the other hand, I felt that they were vastly superior to modern Blues and far more consistent.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #11 on: Fri, 25 November 2016, 20:48:19 »
It will have an MX Green spacebar switch probably.
The controllers on these are fantastic. You should take it apart and look at the insides, they are really interesting in comparison with new boards.
« Reply #12 on: Sun, 27 November 2016, 16:11:41 »
It got delivered today. Had no idea USPS delivered on Sundays!
These blues do feel different.
« Last Edit: Sun, 27 November 2016, 16:17:55 by bexleycorona »
« Reply #13 on: Sun, 27 November 2016, 17:17:45 »
Ugh, it looks like the + keycap isn't standard. Would I most likely only be able to use this on a TKL board?
Offline keykaiser
« Reply #14 on: Sun, 27 November 2016, 17:49:38 »
Is that a trackpoint on upper right corner?
Offline ghostjuggernaut
« Reply #15 on: Sun, 27 November 2016, 18:29:10 »
You would need a compatibility kit in order to use it on a modern TKL. You should be able to use it on a WKL TKL, but will need to find a right shift. Pretty much 1800 sets are only good for 1800 boards.
« Reply #16 on: Sun, 27 November 2016, 18:42:18 »
Yes, it is.
Does that make you hot and bothered?
« Reply #17 on: Mon, 28 November 2016, 15:50:31 »
Are the trackpad PAC 65 variations more desirable?
What's the safest way to clean the keycaps?
« Last Edit: Mon, 28 November 2016, 16:06:24 by bexleycorona »
Offline merlin64
    • MechMerlin
« Reply #18 on: Tue, 29 November 2016, 00:13:34 »
Buy some dental tabs from the grocery store and mix them in a solution of lukewarm water and keycaps. Wait 20-30 minutes, and rinse them. Best way to clean keycaps, and legos.
Offline jcoffin1981
« Reply #19 on: Mon, 05 December 2016, 14:42:59 »
I soak them in luke warm soapy water for about 10 minutes and swish them around.  A pint glass works well.  This is probably the most thorough.  You can also use windex (ammonia free) and lens paper or laboratory wipes.  I actually use Glass Plus as it's difficult to find ammonia free windex.  This is very mild and helps to cut through grime.
