Author Topic: IBM model F XT and model M 13910401 "ESC" keycaps compatible?  (Read 2300 times)
Offline supermario802.1
    • tinkerBOY
« on: Thu, 24 November 2016, 00:21:46 »
I have an IBM Model M 13910401 with a missing "ESC" keycap and was just wondering if I can get it from a model F XT keyboard? Are they the same? I know that the "ESC" key from the Model F is a one-piece assembly while the Model M i mentioned uses two-piece assembly. But are they interchangeable?
Or can anyone point me where to get one?
Thanks.
Offline mike52787
  • Alps Aficionado
Re: IBM model F XT and model M 13910401 "ESC" keycaps compatible?
« Reply #1 on: Thu, 24 November 2016, 18:02:03 »
Of course they are, all BS switches use the same stem.
    • tinkerBOY
« Reply #2 on: Fri, 25 November 2016, 03:00:09 »
ok thank you.
I hope some has an "ESC" keycap here.
