Author Topic: Will this aftermarket case fit the Pok3r w backlit or RGB  (Read 2950 times)
Offline Ryuzaki
« on: Sat, 26 November 2016, 17:16:53 »
I am planning to buy a pok3r and I was wondering when just in case I want to change the case for a different color with something like these:
https://nl.aliexpress.com/item/Wholesales-GH60-Anodizing-Aluminum-Case-for-60-Mechanical-Gaming-Keyboard-Compatible-Poker2-Pok3r-Faceu-60/32540926035.html?spm=2114.010208.8.43.ItmCWY.
However I have heared that the RGB version comes with a extra layer for the RGB light and that it wont be good fit with these cases. But how about the version with the white backlit?
or are there other cases that will fit those? I would like to have some sort of light when the room is dark either be RGB or backllit.
Offline captsis
  • Formerly matt2dlg
Re: Will this aftermarket case fit the Pok3r w backlit or RGB
« Reply #1 on: Tue, 29 November 2016, 13:50:08 »
That case will fit.
Offline Ryuzaki
« Reply #2 on: Tue, 29 November 2016, 15:54:53 »
 I saw some post that people mentioning it wont be a good fit since it has a double layer PCB on the RGB version oppose to the non rgb version. I guess I was missinformed
Offline Ryuzaki
« Reply #3 on: Thu, 01 December 2016, 09:02:18 »
How about replacing the keyboard frame is that easy on a poker keyboard? are they attached with screws or glued?
Offline 14u2nv
« Reply #4 on: Wed, 10 May 2017, 17:44:34 »
Any update on this? Did the case fit? is the pok3r rgb case glued or screwed in?
