Author Topic: [GB]TGR-910 - Completed  (Read 225753 times)
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
Re: [GB]TGR-910 - 75% completed
« Reply #500 on: Thu, 07 September 2017, 08:38:13 »
Can i haz a slot in that re-run ? :)
Offline Sissy
« Reply #501 on: Thu, 07 September 2017, 08:50:03 »
There is an interest Check thread up for it, get excited
Finally done building this bad boi  :thumb:
Thanks yuktsi  :-*
Ur giving byker a run for his money!!!!
He needs a GMK set to make it ultra pretty.
Very true, this boi deserve the best keyset  :-*
Hint: blue alert  :p
Sky dolch would look great also
Offline lildragonbuns
  • Formerly ilovekeycaps
« Reply #502 on: Thu, 07 September 2017, 14:26:47 »
177736-0
177738-1
 :D :D :D :D :D
Offline pixelpusher
« Reply #503 on: Thu, 07 September 2017, 14:27:58 »
Offline smittysteve
  • Tea > Coffee. Clack > Thwock.
« Reply #504 on: Thu, 07 September 2017, 14:28:55 »
Offline mrboovn
« Reply #505 on: Fri, 08 September 2017, 01:10:18 »
Got mine today.Thanks Sam :D
Offline smittysteve
« Reply #506 on: Fri, 08 September 2017, 01:16:17 »
Beauties!!  :thumb:
What is the different marking in the upper 910 blocker spot on the gray board? It's clearly a 910 as well, but did the SE have a different logo cut up there?
Offline nocturalowl
« Reply #507 on: Fri, 08 September 2017, 01:16:32 »
 :D :D :D :D :D
Wow!  All that purple!
wish i can have one in blue and one in purple
T.T
Offline kawasaki161
« Reply #508 on: Fri, 08 September 2017, 04:05:16 »
Beauties!!  :thumb:
Looks like it says VKC, so I assume it's the Vietnam Keyboard Community edition.
« Last Edit: Fri, 08 September 2017, 05:41:49 by kawasaki161 »
Offline yuktsi
  • Colour my life with the chaos of trouble
« Reply #509 on: Fri, 08 September 2017, 05:27:28 »
Beauties!!  :thumb:
Looks like it says VKC, so I assume it's the Vietnam Keyboard Club edition.
Right, that shade of gray and the green plate are specially made for the Vietname Keyboard Community.
email: yuktsi@ttggrr.cc
My collection
Poker 2 | LZ CE | Leopold FC700R | KMAC 1.2 | EXE | GON NS87 | GON Nerd TKL | Duck Poker | Duck Orion | Realforce 87u 55g | OTD 456GT | LZ B7 | OTD 360C | Ducky G2 Pro | Apple Extended | Apple M0116 | Apple M0116 | Cherry G80-1220HAD | Duck Octagon | HHKB Pro 2 | Duck Unicorn | LZ B8 | LZ RE | ENVKX | OTD 456GT | LZ FE | HHKB Type S | TX1800| Duck Orion V2 | LZ FE | KPad | KMAC Happy | ENVKX | LZ RV | KMAC 2 | Whale | Dolphin | EM7 | TGR Jane | VE.A | DK Saver | Matrix 10xv1.0 | Whale | HHKB BT | Dolphin v2 | EM7 v2 | SSK | SSK (Blue Label) | LZ SQ | Duck Octagon v2 | TX84 | GON Mobik | TX-CP | LZ Ergo2 | KMAC Happy HHKB | TGR 910 | TGR Tris | Matrix 8xv1.2 | KMAC Mini | Mira | Fjell | 356mini | Dolphin GH | EM7 GH | TARO EXENT | Masterkey Pro L Crysta l OTD Koala | Duck Viper | Keycult no.1 | 356mini | 356pad | Matrix 8xv2.0 | 420cl | Matrix 8xv1.0 | Whale Special | Poly Dolphin | Keycult No.2 | FMJ80 | Singa R2 | Whale Poly | 356cl | HBCP | Dolinger | Linger | FMJ80 | KFE
Offline nocturalowl
« Reply #510 on: Sun, 10 September 2017, 01:24:12 »
No wonder this board feel really solid. Turn out the 910 was 65% with the weight of TKL. The TKL in above pict is Lynn Dolphin v2 which is rather heavy for a kustom TKL
Good job Yuktsi  :thumb:
Offline yuktsi
« Reply #511 on: Sat, 16 September 2017, 23:06:52 »
If you are interested in ordering additional parts for your 910
Brass plate & PCB - 80$
Brass blocker for 910 cutout - 20$
RGB kit - 15$
https://goo.gl/forms/l2q5LNGLz5G9Ip443
<3
My collection
« Reply #512 on: Sat, 16 September 2017, 23:43:30 »
Brass PCB?
Offline LDobler
« Reply #513 on: Sun, 17 September 2017, 04:37:26 »
RGB kit - 15$
<3
Does the Brass blocker also work for the TGR-910 CE? :)
Offline kawasaki161
« Reply #514 on: Sun, 17 September 2017, 04:43:20 »
RGB kit - 15$
<3
It already comes with one
Offline Sissy
« Reply #515 on: Sun, 17 September 2017, 04:45:50 »
Offline LDobler
« Reply #516 on: Sun, 17 September 2017, 05:03:12 »
RGB kit - 15$
<3
Thanks man, didn't realize that... :thumb:
Cheers
Gesendet von meinem SM-G920F mit Tapatalk
Offline sundin
« Reply #517 on: Sun, 17 September 2017, 05:11:44 »
The dolphin didn't have of brass weight right?
Offline Minha
  • I Don't Want To Die Like Cobain
« Reply #518 on: Sun, 17 September 2017, 05:35:11 »
Dolphins have aluminum weight
Offline oatmicro
« Reply #519 on: Sun, 17 September 2017, 08:35:40 »
RGB kit - 15$
<3
I wish I can get only the brass plate, I already have an extra aluminum plate+pcb in my 910 order.  :'(
« Reply #520 on: Sun, 17 September 2017, 11:05:03 »
Is brass good for linears?
Offline kawasaki161
« Reply #521 on: Sun, 17 September 2017, 11:06:43 »
I personally love brass with linears.
Offline pixelpusher
« Reply #522 on: Sun, 17 September 2017, 12:53:44 »
I still don't think the plate material makes that much difference in feel.  Plate vs. no plate, yes probably. But material, not much.  I know i'm in the minority here, but I believe (again, not the majority opinion here) the vibrations from the switches resonate through the PCB and and then wherever it attaches to the case.  The biggest difference is the case material and sound dampening between the case and the place where it contacts the PCB.
This is my experience with 10 or 11 builds.
Offline kawasaki161
« Reply #523 on: Sun, 17 September 2017, 13:11:31 »
That's what happens when you mostly build tray mounted keyboards, because the PCB does not directly contact the case anywhere in a top mounted build like this where plate material plays a much bigger role.
Here the plate is attached to the case and leaves the PCB floating under it, different plate materials offer different amounts of flex in this case and the plate is doing most of the work of holding things in place. In a tray mounted build you always have the PCB directly on mounts on a solid block of whatever material you chose, providing a lot less flex around those mounting points and having the PCB do most of the work.
Offline pixelpusher
« Reply #524 on: Sun, 17 September 2017, 13:13:40 »
Very good point.
« Reply #525 on: Sun, 17 September 2017, 13:28:27 »
I'll order one just for giggles.
Offline usb
« Reply #526 on: Mon, 18 September 2017, 02:53:38 »
I like 910se very much, how can I buy it
« Reply #527 on: Mon, 18 September 2017, 06:52:20 »
By clicking the purchase button.
Offline Damonskv
« Reply #528 on: Wed, 20 September 2017, 03:08:12 »
Finally got this beauty!!!! Thanks Sam, it's amazing
Offline avid
« Reply #529 on: Wed, 20 September 2017, 03:25:02 »
The pink is gorgeous. What keyset do you plan to use with it?
Offline Damonskv
« Reply #530 on: Wed, 20 September 2017, 03:40:31 »
I think about jtk pink, or maybe plain gmk beige
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #531 on: Fri, 22 September 2017, 14:09:38 »
« Reply #532 on: Fri, 22 September 2017, 14:44:52 »
Offline Sissy
« Reply #533 on: Fri, 22 September 2017, 20:38:12 »
Full Album Here
Stunning, this is the grey color yea?
I'm damn excited for my CE
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #534 on: Fri, 22 September 2017, 22:13:07 »
Full Album Here
This is the grey yes! Love it in person!
Offline doostin
Re: [GB]TGR-910 - 80% completed
« Reply #535 on: Mon, 25 September 2017, 20:00:11 »
Any tips for reducing the pinging sound on this board? I'm a heavy-handed typist and the pinging is quite noticeable. I've considered adding a thin foam pad under the PCB, but that would block all the lighting underneath.
« Reply #536 on: Mon, 25 September 2017, 21:02:08 »
Do you have a deskmat? And lubing can be pretty helpful in reducing ping.
Offline yuktsi
« Reply #537 on: Tue, 26 September 2017, 11:34:12 »
Try removing the diffuser and add the PE foam that comes with the board underneath.
My collection
Offline wodan
« Reply #538 on: Wed, 25 October 2017, 05:31:35 »
Can we get a status of the units that are still delayed?
It's been dead for almost a month now, looking for a silver lining...
Offline Blackhawk
« Reply #539 on: Wed, 08 November 2017, 15:11:49 »
RGB kit - 15$
<3
Hey yuktsi, any update for people who filled in this form? Never received an invoice
Offline onmybikedrunk
    • Danny Woods - Industrial Designer
« Reply #540 on: Thu, 09 November 2017, 14:55:30 »
Sam, I just got my 910 and your boards are incredible.  This goes to the top of my collection for sure.  Thank you so much for all your hard work and dedication to the community.  Your perseverance equates to a quality product that is unforgettable.
FULL IMGUR POST
« Reply #541 on: Thu, 09 November 2017, 15:03:46 »
FULL IMGUR POST
hot
Offline neralo
« Reply #542 on: Thu, 09 November 2017, 19:55:07 »
RGB kit - 15$
<3
oh man you just reminded me that I filled in this form too, wanted to get a brass blocker.
HHKB Pro 2 55g | TGR 910 55g Vintage Blacks | Apple Standard M0116 Orange Alps | Rosewill RK9000 Cherry MX Blues | Diverge TM 2 WKLears
« Reply #543 on: Fri, 10 November 2017, 18:09:02 »
Has anyone had any RGB issues with their boards?  I have two PCBs and have only half the RGBs lighting up on one and only 3 on the other.  Neither one is lighting up the "910" front RGB.  Any ideas?  I find it odd that both PCBs are having similar issues.  I reflashed the firmware/keymap and then did a reconnect with the RGB Settings under Bootmapper and nothing helped.  I also tried adjusting the number of LEDs on Bootmapper and nada.  Any help would be appreciated!!
Offline codywanks
« Reply #544 on: Fri, 10 November 2017, 20:51:51 »
Assuming the 910 has 12 RGB LEDs, if RGB #7 isn’t working properly, RGB #8 to #12 won’t light up either. This is because they’re chained together in series.
In this example, RGB #7 probably has dry solder joints on a couple of its legs. The fix is simple. You’ll simply need to reflow the solder by touching the dry joints with the tip of your iron (do it for all four legs just for the sake of thoroughness). Make sure the iron is sufficiently hot that you don’t need to hold it there for more than a couple of seconds. You may also add extra solder to each of the four legs if it makes you feel better, but don’t overdo it.
This ought to wake the LED up and complete circulation to the rest of the chain.
« Reply #545 on: Fri, 10 November 2017, 23:06:02 »
Yeah I tried this already and it did work on one PCB, but not the other. Then I attempted to replace the bad SMD (which I have done a few times prior) and it lifted a pad (eek).  At least I have one fully working PCB tho.  Hopefully Yuktsi and I can work something out... Thank you for your help!
Offline wodan
« Reply #546 on: Fri, 24 November 2017, 01:39:57 »
Can I please get an estimate when the remaining 20% will be finished?
Along with the TGR-910CE? Any time soon?
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #547 on: Fri, 24 November 2017, 14:55:42 »
Made a little alteration to my 910 weight last night
Offline neralo
« Reply #548 on: Sun, 26 November 2017, 19:39:01 »
Damn that is classy af
« Reply #549 on: Sun, 26 November 2017, 22:19:37 »
HOT
