Author Topic: [IC] GMK Olivetti & Screw-in Stabilizers  (Read 88582 times)
Offline Tom_Kazansky
  • Oblivion Knight
Re: [IC] GMK Olivetti & Screw-in Stabilizers
« Reply #150 on: Wed, 14 December 2016, 20:00:16 »
I'm in for some screw-in stabs ;D
Offline neon_tom
« Reply #151 on: Wed, 14 December 2016, 20:30:46 »
I know this is off topic but I would like to see GMK Dolch with Icons modifier(like Ivan Dolch)
I'd love to see this as well. The exact same keys cmd has in his Olivetti render but in Dolch colors. I'd be down for both sets. Hopefullly Dolch in a future GB!
Offline dr-slump
« Reply #152 on: Wed, 14 December 2016, 20:38:54 »
Definitely in if ISO Norde/German becomes available
Wanted an Olivetti set in German for ages
Waiting for GMK Miami Dolch ISO . . .
Looking for: Titainium Spacebar 6.25
Offline blighty
« Reply #153 on: Wed, 14 December 2016, 23:10:35 »
I suggest that you start an IC for an add on kit :)
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
Offline cmd
« Reply #154 on: Thu, 15 December 2016, 06:31:38 »
If I do an iso kits it's more or less all or nothing for you guys. I will be taking out all ISO keys and putting them in a separate kit. If it doesn't hit MOQ you guys are donezo haha.
Sent from my Nexus 6P using Tapatalk
Offline cmd
« Reply #155 on: Thu, 15 December 2016, 07:30:37 »
This confuses me
Offline ideus
  • Björkö.
« Reply #156 on: Thu, 15 December 2016, 07:37:05 »
An ISO kit like this? With no duplicated keys, of course.
Offline cmd
« Reply #157 on: Thu, 15 December 2016, 07:42:13 »
Yessir, like this.
This is the int'l extension:
https://i.imgur.com/XAmS4py.png
« Last Edit: Thu, 15 December 2016, 07:49:43 by cmd »
Offline ideus
  • Björkö.
« Reply #158 on: Thu, 15 December 2016, 07:52:24 »
Yessir, like this. Are there more essential keys?
An 1.5u Alt Gr key would be great; but, I think non of the Alt Gr keys are really essential. They can be replaced with the standard Alt keys with no issue. These keys provide full ISO UK compatibility to the set. The other European layouts require a lot more keys; that, it is not the intent of this essential ISO child set.
Offline cmd
« Reply #159 on: Thu, 15 December 2016, 07:58:20 »
Ya bro I got you. Leandre helped me with it. Wodan's essentials are what I will use. As for the first part - I have 1.5U Alt Gr in both R4 and R5. It is in the main set. The 4 ISO keys will stay in the main set.
Offline dr-slump
« Reply #160 on: Thu, 15 December 2016, 08:14:48 »
This confuses me
It confuses me, that it confuses you  :D
All jokes aside. - What exactly does confuse you?
BTW: I'm definitely in for the main set with the essentials
« Last Edit: Thu, 15 December 2016, 08:25:07 by dr-slump »
« Reply #161 on: Thu, 15 December 2016, 09:43:06 »
This confuses me
How's Arale?
Offline cmd
« Reply #162 on: Thu, 15 December 2016, 10:36:31 »
International Kit added.
:Trump:
and yes, you are fk bois
« Last Edit: Thu, 15 December 2016, 10:39:02 by cmd »
Offline trenzafeeds
  • **** off
« Reply #163 on: Thu, 15 December 2016, 10:47:36 »
****, gmk with intl kit. how much extra do you expect that to be?
WOW I SHOULD READ THE ****ING OP
demik will never leave.
Unless he gets banned.
« Reply #164 on: Thu, 15 December 2016, 10:52:42 »
Don't forget to add diamond modifiers.
Offline tobsn
« Reply #165 on: Thu, 15 December 2016, 10:55:37 »
@cmd "+/-" you mean "~" :)
Offline dr-slump
« Reply #166 on: Thu, 15 December 2016, 11:11:28 »
This confuses me
How's Arale?
Doing just fine.
She just told me that she wants that Olivetti Set before X-Mas  :))
Offline cmd
« Reply #167 on: Thu, 15 December 2016, 11:14:32 »
Lol. In ur dreams.
Yes sir.
Offline awhitedev
« Reply #168 on: Mon, 19 December 2016, 05:50:17 »
Not sure if this has been asked... sorry if it's redundant or a bit too early to ask.
Are you planning to use a vendor to collect payment and ship for you? (Originativeco, Massdrop, etc.) If not, where will these be shipping from?
PS. Definitely interested in this. I always love classic looking sets.
Offline Giorgio
« Reply #169 on: Mon, 19 December 2016, 07:07:38 »
Are the screw-in modifiers dangerous for your pcb?
With the usual stabs, when I remove a spacebar which has very tight stems, the stab may be accidentally removed without damaging the pcb (it has happened to me with an original cherry 6u spacebar). When using the screw-in ones, is there a possibility that they can damage the pcb?
I'm also curious if there's any real difference in stability from screw in to pcb mounted stabilizers...
Offline cmd
« Reply #170 on: Mon, 19 December 2016, 07:59:05 »
No they are not dangerous to your PCB (unless you are an idiot). GMK used them in their skidata boards and Zeal also has replicated them (as well has enhance their features). I am fairly certain they do in fact increase stability since they are locked in.
Also, they are pcb mounted stabilizers except that they are screw-in. Refer to Leandre's photos on Page 2.
Offline satricion
« Reply #171 on: Mon, 19 December 2016, 23:36:59 »
This is a great set and I'd be throwing money at a GB.
Offline poolside
« Reply #172 on: Tue, 20 December 2016, 04:14:13 »
Mmmh, every time I pop this thread open, I find that Olivetti colorway growing on me. Might be the blue.
Offline LDobler
« Reply #173 on: Tue, 20 December 2016, 05:19:05 »
Looks good, if my budget allows it I'm in for a set + Int kit  :thumb:
Offline ideus
  • Björkö.
« Reply #174 on: Wed, 21 December 2016, 12:36:33 »
The set looks great. It is very hard to resist for my poor wallet now. I just hope, I can secure wife's approval for the purchase. LOL.
Just a couple of questions:
1) Are the windows key double shot or pad printed?
2) Would the UK keys: R3 #~ and R4 \| belong into the main set better than R3 # ' and R4 <>|  Germanic ones?
A German fellow will need the international set anyway; so, it makes more sense to keep all the Germanic keys in there. Don't you think? In the other hand the UK keys R3 #~ and R4 \| complements the main set ala XT style making it a full set with an ISO or with an ANSI Enter. The Germanic keys: R3 # ' and R4 <>| are redundant with the ANSI layout of the main set.
Offline YH YOON
« Reply #175 on: Fri, 23 December 2016, 05:12:56 »
in :)
Offline ticktwo
  • -kbdfan
« Reply #176 on: Fri, 06 January 2017, 18:26:49 »
would still start around January or February?
Sent from my SM-G935F using Tapatalk
HHKB | Leopold FC750R | Mech27 (soon) | TX-75 (soon)
Offline Giorgio
« Reply #177 on: Sat, 07 January 2017, 02:28:32 »
Any chance of adding some keys to the international kit? I'm asking this because gmk has a strange threshold, and if you get past it, everything becomes cheaper, and 1u keys cost about $0.5.
For example in the alphas set I had 74 pieces for $50, and additional 1u keys cost 0.5$, while the space bar cost 1.5$ https://geekhack.org/index.php?topic=85593.0
I'm suggesting to add a 6u space-bar and 5 1u keys for modern 1800 compatibility.
Offline afrokobe
« Reply #178 on: Sat, 07 January 2017, 18:40:04 »
I am definitely in for screw in stabs.
Offline need
« Reply #179 on: Wed, 11 January 2017, 18:59:43 »
In for many sets of screw in stabs, just can never have too much of them.
Offline K.Mak
« Reply #180 on: Thu, 12 January 2017, 12:38:36 »
The stabilizers would be pretty much identical to Zeal's, minus the gold wire and transparent plastic right? If so, I'd buy enough for all the boards I will ever build. I love Zeal's stabilizers but 30 bucks for a set, particularly when not all my boards require transparent stabilizers due to lack of RGB, oof.
Offline mech0nly
« Reply #181 on: Wed, 18 January 2017, 01:10:48 »
interested for olivetti, i hope my wallet still ready after dolch  :)
« Last Edit: Wed, 18 January 2017, 01:15:57 by mech0nly »
356mini | 360C | G81-3000SAT | G81-3000SAU | G80-3000LPCXY-2 | G80-3485LWNUS-2
Diamond Polished Cherry Switches!
Offline wholypantalones
  • text and icon mods plz.
« Reply #182 on: Tue, 31 January 2017, 22:44:44 »
I'm down for some s few in stabs, that Olivetti too.
Offline loud_asian
« Reply #183 on: Wed, 01 February 2017, 00:46:36 »
The screw in stabilizers that GMK has don't have the nut that zeal's do, they just screw into the plastic. They're still pretty sturdy though
Offline ideus
  • Björkö.
« Reply #184 on: Fri, 03 February 2017, 07:37:01 »
Is this still alive?
Offline cmd
« Reply #185 on: Fri, 03 February 2017, 07:43:38 »
Yes, originative will be dropping it soon^tm...
Offline need
« Reply #186 on: Fri, 03 February 2017, 08:51:06 »
omg...why is it originative  :confused:
I had hopes for some low priced stabs, oh well.
Offline cmd
« Reply #187 on: Fri, 03 February 2017, 12:22:35 »
The prices I have above are the prices that sherry will post them for. I think we are gonna do a full stab set + 6.25/7U.
« Reply #188 on: Fri, 03 February 2017, 15:43:45 »
Eh, no problems with GB delivery from Originative so far except the lack of updates but no biggie. Their pricing on GB items is usually pretty reasonable.
Offline poolside
« Reply #189 on: Fri, 03 February 2017, 16:07:36 »
This will be complemeting Honeywell very ... well.  :)
Offline cmd
« Reply #190 on: Sat, 04 February 2017, 08:10:10 »
Lol, alrighty
« Reply #191 on: Sat, 04 February 2017, 21:20:20 »
Lol, alrighty
K.
Offline hippiepete
« Reply #192 on: Mon, 06 February 2017, 13:19:36 »
in
Offline ricyuyc
« Reply #193 on: Mon, 06 February 2017, 22:45:32 »
count me in
Offline aznreaper
« Reply #194 on: Wed, 08 February 2017, 23:59:12 »
Are you getting oco to do both the keyset and the stabilizers? Was really hoping to get that olivetti set, but I would really prefer not to deal with oco GB's after the whole TADA gong-show
Offline cmd
« Reply #195 on: Mon, 13 February 2017, 14:32:59 »
Hi there...I believe oco will just carry them but I will need to get that by Sherry first. I wouldn't let one moment like that scare you away, that is not GMK. GMK generally will stick to their timelines and this set does not have any custom colors in it. The only person liable for delays would be GMK (when this goes live and deadlines are met). It is rather straight forward.
Cheers
Offline aznreaper
« Reply #196 on: Mon, 13 February 2017, 19:00:11 »
Yeah, the other problem is shipping internationally is crazy expensive it'd you don't have the option to lower declared value which I've heard they will not do anymore. Plus guessing through oco it'll be impossible to have the set sell at the prices you were quoting initially. I'll probably pass since it'll probably be too much to justify with all the other stuff that's coming out, good luck though, the sets really quite nice
Offline cmd
« Reply #197 on: Tue, 14 February 2017, 08:19:58 »
Yeah I've mentioned before that the price is not going to change...it will change when the set goes to retail...but not for the GB.
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #198 on: Tue, 14 February 2017, 08:24:40 »
cool set
Offline cmd
« Reply #199 on: Tue, 14 February 2017, 11:00:32 »
