Author Topic: What kind of stabilizers do Max / Tesoro keyboards use?  (Read 1924 times)
Offline Entropia
« on: Wed, 30 November 2016, 13:53:18 »
I'm asking this because I own a Tesoro Durandal G1N, which is made my Max Keyboards and I find the long keys feel and sound exactly like they should, with no difference from the rest of keys.
On the other hand, once I tried a Cherry G80 and I returned it because the long keys felt terrible, mushy and with no mechanical feel or sound. Is that what I should expect from any keyboard with Cherry stabilizers or is it just an issue with this specific brand and model?
Offline FrostyToast
  • Litshoard
Re: What kind of stabilizers do Max / Tesoro keyboards use?
« Reply #1 on: Wed, 30 November 2016, 13:56:26 »
It would help greatly to provide pictures of the stabilisers in question before anything is said.
Quote from: elton5354
Offline Entropia
« Reply #2 on: Wed, 30 November 2016, 14:19:05 »
I don't have photos. I have never removed the long keys from my keyboard. I'm scared I could break anything or not being able to reinstall the keys.
Offline saxophone
« Reply #3 on: Fri, 02 December 2016, 02:14:23 »
Tesoro uses costar stabs. They have a thinner wire than the usual costar ones however.
Offline Entropia
« Reply #4 on: Fri, 02 December 2016, 05:45:22 »
Then, for my new keyboard maybe I should take this into consideration and demand Costar stabilizers as a priority.
Is there any list where I can see what is used in every brand / model? I know Filco uses Costar and Leopold Cherries. I think that Ducky also uses Cherries, if I'm not wrong.
Should I avoid Cherry stabilizers?
Are these (Costar and Cherry) the only stabilizers brands that I could expect to find in most keyboards?
What is commonly used in more gaming, cheap or mainstream mechanical keyboards?
Offline davkol
  •  Post Editing Timeout
« Reply #5 on: Fri, 02 December 2016, 12:04:01 »
Costar and Cherry are two major stabilizer *designs* in keyboards with MX-compatible switches.
Costar stabs are used on keyboards made by Costar; Cherry stabs are used on keyboards made by, uh, Cherry and some others (KUL, Leopold,…). Most others are similar or clones. For example, iOne keyboards (pre-2013 Razer BlackWidow, the Tesoro board in question,…) have wire stabs similar to Costar, but thinner and flimsier.
Wire stabs are annoying, when removing/installing keycaps and may grind against keycaps/switches, thus I'd avoid them and stick to Cherry. If you don't like the damped/mushy feel of Cherry stabs, those can be clipped to get crisp feel (Ducky does something like this in production). Tape/lube helps with rattle in either design.
Offline Entropia
« Reply #6 on: Fri, 02 December 2016, 14:27:43 »
Thanx for the info. I'm actually very happy with the stabs in my Tesoro, although I have not tried many mechanical keyboards to compare. One of the main candidates to be my new keyboard is the Ducky One grey non-backlit with thick pbt keycaps, but I was a little worried about what people say about Cherry stabs. However, if you say that they've been improved for better feel, that's good news. To be honest, I don't want to spend a lot of money in a great keyboard and have the long keys feel like rubber domes, as happens with the Cherry G80 model.
