Author Topic: help me piece together xda kits for this  (Read 2336 times)
Offline saxophone
« on: Sat, 03 December 2016, 10:51:42 »
I want to buy the XDA keycap set for the kananic dkd.
I'm however unsure about which kits that are needed.
These are the keycaps on it that differs from the common ANSI TKL layout
1.5u esc, del
1.25u arrows, shift , end
1u ctrl
Need help with which packs that I need to buy to replace em all or alternatively, suggestions for what I should get to replace them if keys dont exist in those packs.
Offline Auxo
  • Formerly CJD_Anthony
Re: help me piece together xda kits for this
« Reply #1 on: Sat, 03 December 2016, 14:09:32 »
1.5u esc, del
1u ctrl
1.5u delete and 1u ctrl is in the modifier plus options...
XD Arsenal has the 1.25 shift and arrow keys
I don't see any options for a 1.5u esc or 1.25u end
