Author Topic: [IC] SA Vault  (Read 4360 times)
Offline dsaf
[IC] SA Vault
« on: Sun, 04 December 2016, 17:25:43 »
This is just an idea at the moment. All of the art/icons was ripped from internet. (No copyright infringement indented!)
Inspiration:
Possible options:
154640-1
154642-2
154644-3
Possible novelties:
Mood soundtrack (featuring clicky keyboard at 1:00):
Offline Floody
  • Formerly Flood
  • But is it?
Re: [IC] SA Vault
« Reply #1 on: Sun, 04 December 2016, 18:32:13 »
The spacebar stands out too much. I also suggest you make your own icons.
Offline Oblotzky
  • Backspace is for people that make mistakes.
Re: [IC] SA Vault
« Reply #2 on: Mon, 05 December 2016, 01:42:44 »
It can work very well, but being optional would be best I think.
Offline jchan94
  • Keyclack Inc
  • Please email jchan@keyclack.com. PMs are disabled
    • KeyClack
Re: [IC] SA Vault
« Reply #3 on: Mon, 05 December 2016, 06:27:18 »
I'm personally not a fan of the colors, but I understand their usage.
Personally, I'd suggest trying...
White Alphas, Blue Legends
Yellow Mods, Black Legends
...OR...
Yellow Alphas, Blue Legends
Grey Mods, White Legends?
Support Email: support@keyclack.com
Did you miss something from us?
- Sign up for our Mailing List: https://eepurl.com/coAJ5r
Offline Fictiouz
  • That "White" Guy
Re: [IC] SA Vault
« Reply #4 on: Mon, 05 December 2016, 07:23:41 »
I would suggest trying to color match some of the already created Fallout novelty caps and work backwards from there. I'm not a huge lover a the current color schemes.
Offline e_l_tang
Re: [IC] SA Vault
« Reply #5 on: Mon, 05 December 2016, 12:38:30 »
Isn't this a duplicate of The Blue Jumpsuit?
Offline dsaf
Re: [IC] SA Vault
« Reply #6 on: Mon, 05 December 2016, 15:39:52 »
No, unless it will switch away from DSA/SA-R3 to a sculptured set. Also that one is more Fallout 3/4 inspired, this one is strictly Fallout 1/2 inspired. Though there is naturally a big overlap!
That would make sense.
I get what you are saying. Maybe it doesn't have to be precise reproduction of the key palette.
It should be appealing to not just Fallout fans.
Yes, it would be optional.
I just wanted to see whether there is any interest before investing any time into proper icons. They would be easy/doable to redraw in a custom way. I would probably need vectors for manufacturer anyway...
Offline fax668
  • Shaken, not stirred
Re: [IC] SA Vault
« Reply #7 on: Wed, 07 December 2016, 03:05:15 »
I like the third variant with green alphas. It's different.
