Author Topic: Help with LZ Iron  (Read 1650 times)
Offline iArson
Help with LZ Iron
« on: Sun, 04 December 2016, 20:01:58 »
Long story short, I can't figure out how to work the LED's with this board. I've contacted LZ, but I feel bad bothering him and I was curious if anyone could help me set them. I'm using the JigOn Software. Thanks!
Offline kawasaki161
Re: Help with LZ Iron
« Reply #1 on: Mon, 05 December 2016, 07:34:36 »
Someone tried making a English documentation for the Leeku PCB's which I believe are used in the LZ Iron.
https://geekhack.org/index.php?topic=83950.msg2236885#msg2236885
Maybe this'll help.
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #2 on: Mon, 05 December 2016, 08:49:55 »
Maybe this'll help.
This has helped me a ton, so good suggestion.
Once you get used to the software it isn't that bad. Just can be a little confusing st first glance.
Offline iArson
« Reply #3 on: Mon, 05 December 2016, 15:05:45 »
I used this the other day, but for some reason I'm not able to actually change any of the LED functions. I'm not sure if its this specific PCB, but there are lights at the bottom that work with the LZ Iron case. Default they're Blue orange and Red, but after restarting my rig they revert to Orange purple and purple. I can't tell if my board is even connecting in the software for me to change anything.
