Author Topic: Questions about making my first keyboard  (Read 5430 times)
Offline tktktktk
« on: Mon, 05 December 2016, 10:58:57 »
Hi! I know custom keyboards are probably a question that often comes up, but after some research I couldn't find answers to some of my questions, so here I am.
Being a student in math / physics, I'd like to build a keyboard that would allow me to type easily for these subjets, including mathematical symbols and greek letters. I know it's something I could do with a software solution, but I find this project amusing.
The first thing is that… I'm French. So I'm used to using an AZERTY keyboard, which has, besides the different layout for letters, a different "numbers row" layout.
How do I do this? I mean, my question is probably stupid, but when I'll have my keyboard finished, what will Windows see it like? Do I just have to reproduce the layout with corrent places for letters, and putting the numbers at the place they would be on a QWERTY keyboard (that would make sense in my opinion since the keyboard only sends signal, I guess Windows recognizes the "Key 2" signal and then converts it depending on the active layout: 2 for QWERTY, é for AZERTY, etc. That was my first question.
Second, and concerning the custom features.
Here is a prototype of the layout I'd need. The alpha on the bottom right is a modifier for the greek letters mode, and the blackboard R for the "math" mode.
Well… how do I do that?
I plan to use QMK since it supports Unicode and (afaik) I have to use unicode if I want to produce all these symbols. Is there a better way to do it than configuring a layer for each "mode" and putting Unicode codes on the corresponding layers?
Last, concering the hardware. How is a keyboard made? I mean, I understand the matrix thingy, the switches, the electronics in a general way, but I don't really get what is put on what. After browsing the /r/mk FAQ - and yours - I didn't find anything related to that.
Would anyone have a scheme or something that could explain what the keyboard is supposed to look like?
Thank you for your answers
EDIT : I was also wondering. When keymapping, to get my AZERTY layout, should I rather do that:
Code: [Select]
        KC_GRV,   KC_1,    KC_2,    KC_3, KC_4, KC_5, KC_6, KC_7, KC_8, KC_9,    KC_0,    KC_MINS, KC_EQL,   KC_BSPC,   \
        TAB,      KC_A,    KC_Z,    KC_E, KC_R, KC_T, KC_Y, KC_U, KC_I, KC_O,    KC_P,    KC_LBRC, KC_RBRC,  KC_BSLS,   \
Or that:
Code: [Select]
        TAB,      KC_Q,    KC_W,    KC_E, KC_R, KC_T, KC_Y, KC_U, KC_I, KC_O,    KC_P,    KC_LBRC, KC_RBRC,  KC_BSLS,   \
If I'm not wrong, the first one will work as an AZERTY Layout if the Windows Layout is a QWERTY layout, and the second will work as an AZERTY layout if the Windows layout is QWERTY. Am I right or didn't I understand anything?
« Last Edit: Mon, 05 December 2016, 13:38:55 by tktktktk »
Offline Nitrax
  • Math deserves its own keyboard
    • mathematicalkeyboard
Re: Questions about making my first keyboard
« Reply #1 on: Thu, 22 October 2026, 13:32:02 »
Quote from: tktktktk
Old thread, but I ended up building something very close to this: Nitrax, a keyboard with printed math and Greek symbols.
My approach was to have the keyboard send key combinations and let companion software handle the character insertion. I've documented the layout and software approach in this technical description of my implementation, if it's useful to anyone working on a similar project.
I designed a keyboard dedicated to typing math symbols — curious what fellow keyboard enthusiasts think!
Nitrax Mathematical Keyboard
Offline miabrown432
« Reply #2 on: Mon, 16 November 2026, 21:24:32 »
I like the idea of using key combinations with companion software instead of trying to handle every symbol directly through QMK. It seems like a much more flexible approach, especially for something as specialized as mathematical and Greek characters. Definitely going to check out the technical documentation!  basketball stars
