Author Topic: Fix the HTTPS PLEASE!  (Read 13261 times)
Offline GreyAmbience
  • I can stop when ever I want
« on: Mon, 05 December 2016, 15:07:55 »
I haven't been able to use slack since the https problem startet :( I can not load any topics at all.
Can't someone fix it?
Offline infiniti
  • I <3 KB
  • Bob was here
Re: Fix the HTTPS PLEASE!
« Reply #1 on: Mon, 05 December 2016, 23:26:34 »
Have you tried clearing cache?  Logging out and in again?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #2 on: Mon, 05 December 2016, 23:39:55 »
Everything works for me except using Tapatalk after the https started acting up.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #3 on: Mon, 05 December 2016, 23:47:21 »
I'll go get an admin to look into this.
« Reply #4 on: Tue, 06 December 2016, 05:59:38 »
Slack is totally separate from the geekhack forums. The HTTPS issues should have nothing to do with slack issues.
And for those with tapatalk, I had to sign out and sign back in to get it to work.
Offline rpeterclark
  • RPTR ❌
« Reply #5 on: Tue, 06 December 2016, 08:47:56 »
I see this message about the SSL certificate whenever I load the site up on mobile:
I can click past it but the warning comes up again after every few clicks. Clearing the browser cache did not seem to have an effect. The SSL certificate _appears_ to be valid, but my mobile device does not trust the CA. The SSL certificate itself shows the same details as the certificate I see from a desktop browser.
Offline traktor
« Reply #6 on: Sat, 10 December 2016, 02:39:02 »
If you configure your servers to send the entire certificate chain (i.e. the concatenation of *.geekhack.org -> COMODO RSA Domain Validation Secure Server CA -> COMODO RSA Certification Authority), then it should work in mobile browsers as well.
Offline rpeterclark
  • RPTR ❌
« Reply #7 on: Sat, 10 December 2016, 05:36:01 »
Yes, the certificate chain is incomplete, that can be verified here: https://www.ssllabs.com/ssltest/analyze.html?d=geekhack.org
You can Google for solutions for specific hosting environments, but the answer is essentially what traktor said. http://stackoverflow.com/questions/36821931/comodo-ssl-err-cert-authority-invalid-on-chrome-mobile-and-opera-mobile-androi
Offline iMav
  • geekhack creator/founder
« Reply #8 on: Sat, 17 December 2016, 18:28:33 »
155632-0
Better??  :)
Offline rpeterclark
  • RPTR ❌
« Reply #9 on: Sun, 18 December 2016, 05:24:39 »
Yes! HTTPS is reporting green and happy for me now on Android. I don't use Tapatalk, someone else will have to confirm that it's been fixed for that app.
Offline iMav
« Reply #10 on: Sun, 18 December 2016, 18:59:55 »
Sorry for the delay.  I just needed to take the time to grab the right chain of certs.  (I'm way too busy these days)
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #11 on: Sun, 18 December 2016, 23:00:06 »
Howdy Sir!
I looked, but it seemed like there was nothing I could do.  The cert itself seemed fine.
The other things Qualys is complaining about should probably also be fixed.  Please advise if me or my guys can help.
 - Ron | samwisekoi
Auto-typed by my GH-122 keyboard.
« Reply #12 on: Sun, 25 December 2016, 10:04:31 »
Howdy Sir!
 - Ron | samwisekoi
Thank you, I found a fix now. I think some bad code somehow got ingrained in my phone or something, but here's how I fixed it; On Android 6+ to go settings > Apps > Gear icon top right corner > Clear app setting.
This resets a lot of app settings for everything so be warned.
Sent from my Nexus 5X using Tapatalk
