Author Topic: Looking for a non pingy mechanical keyboard  (Read 4191 times)
Offline RAZORLIGHT
« on: Thu, 08 December 2016, 08:57:02 »
Hello,
i am looking for a non pingy mechanical keyboard
currently, i am using a corsair K70 with MX brown which pings alot (especially the A key)
now i have a few questions as well:
1. do browns ping more than reds... most ping issues refer to mx browns
2. is there a proper and save way to reduce/eliminate ping (lubing, shelf liner etc.?)
what i absolutely need on a keyboard are dedicated media keys or atleast volume keys
i hope you can help me since the ping noise is driving me crazy
Offline 1391406
Re: Looking for a non pingy mechanical keyboard
« Reply #1 on: Thu, 08 December 2016, 09:16:13 »
I'm not familiar with the pinging you're referring to regarding MX Browns. None of the MX Brown boards I own ping, but O-rings might help. Some thick liner under the board wouldn't be a bad idea, either. I don't know if it's coming from the case, desk or switch in your situation.
Offline RAZORLIGHT
« Reply #2 on: Thu, 08 December 2016, 09:18:23 »
i am referring to the famous filco ping
ps. i tried O-rings, nothing
i tried a something under the keyboard, nothing
i read nearly everything on the internet about the ping issue but nothing worked
ps. the ping sound is coming from the switch resonating with the keyboard case since only a few keys are pinging
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #3 on: Thu, 08 December 2016, 10:41:09 »
Just buy some flimsy piece of crap with no metal in it, like a G80-3000, or a rubber dome derivative like Topre.
Offline menuhin
« Reply #4 on: Thu, 08 December 2016, 11:07:15 »
Perhaps try something with no metal plate inside, e.g. aluminium plate. Acrylic plate or plate-less can even be better to reduce the ping. Also, add some padding / foam underneath the PCB to eliminate empty space.
I was offended by the ping of some older IBM keyboards, and couldn't get use to the handsome Model M13, and eventually went for a rubber dome (IBM KPD-8923), and I'm now still partially a rubber dome person (HHKB with its plate-less Topre domes). I've also converted to linear also, but on a Noppoo 84 Choc-mini there's the steel mounting plate, so even my Gateron blacks with o-rings (to reduce key travel) 'ping', with less echos than the Model Ms in such a smaller 75% case. I kind of like it.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline RAZORLIGHT
« Reply #5 on: Thu, 08 December 2016, 11:18:01 »
tbh. there is not much choice for me since i want to order from amazon(germany)
« Last Edit: Thu, 08 December 2016, 11:20:37 by RAZORLIGHT »
Offline menuhin
« Reply #6 on: Thu, 08 December 2016, 11:39:16 »
... what i absolutely need on a keyboard are dedicated media keys or atleast volume keys
i hope you can help me since the ping noise is driving me crazy ...
Miss this part.
I'll suggest getting a Sun Type-6 or Type-7 USB keyboard on eBay.de - they've some of the most decent domes - they "at least have volume keys". Pressing on Cherry browns are like having key presses suddenly obstructed by a few grains of sand, I couldn't care less for them. Cherry reds are also too light for my taste as I don't like to bottom out if the bottoming out is not 'cushioned' - so I don't have experience for both kinds of switches you mentioned.
Or perhaps this one? A higher-end keyboard with rubber-dome enabled capacitive switches (i.e. Topre):
https://www.amazon.de/gp/offer-listing/B00MY3S288/ref=dp_olp_new?ie=UTF8&condition=new
« Last Edit: Thu, 08 December 2016, 12:18:18 by menuhin »
IBM M13 black
HHKB Pro 2 HasuBT
Offline supamesican
« Reply #7 on: Thu, 08 December 2016, 12:16:19 »
Topre or matias quiet click those are the two best non clicky switches why go any farther?
Offline menuhin
« Reply #8 on: Thu, 08 December 2016, 12:22:30 »
Right, Matias Quiet Pro also has volume control buttons, and it has some modern (simplified) Alps switches 10+ times better than Cherry browns:
https://www.amazon.de/Matias-Tastatur-Quiet-Pro-schwarz/dp/B00C1G624O/ref=sr_1_3?ie=UTF8&qid=1481221131&sr=8-3
Here's the disassembly of its mini brother, the mini Quiet-Pro:
https://geekhack.org/index.php?topic=49920.0
Didn't say if it has a metal plate or not. Rubber-dome boards can ping too, like my Topre-clone board by PLUM because it has a high quality steel mounting plate. The Novatouch seems having only a plastic upper housing, so probably won't ping.
« Last Edit: Thu, 08 December 2016, 12:34:14 by menuhin »
IBM M13 black
HHKB Pro 2 HasuBT
Offline RAZORLIGHT
« Reply #9 on: Thu, 08 December 2016, 13:09:46 »
sorry guys all of those boards you suggested are too expensive :/
Offline menuhin
« Reply #10 on: Thu, 08 December 2016, 13:38:05 »
Doch!
This one (Sun Type 7) though a rubber dome, is less than 24€ shipped and look super badass like a Unix expert keyboard:
http://www.ebay.de/itm/Sun-X3733A-Type-7-USB-Tastatur-und-Maus-deutsches-Layout-565-1815-03/281720679859
IBM M13 black
HHKB Pro 2 HasuBT
Offline Tactile
« Reply #11 on: Thu, 08 December 2016, 14:32:12 »
Before spending money on another keyboard you might try just opening up your keyboard and lining the case with drawer liner. This is a common trick to mellow the sound and it might reduce or eliminate your ping.
REΛLFORCE
Offline Corsa1r
« Reply #12 on: Thu, 08 December 2016, 14:36:02 »
No Leopold I have ever touched has made any type of 'pinging' while typing.
Ducky Shine 4 - Mx Blues // Ganss G.S-87 - Mx Browns // Type-S HHKB 45g // FC660M - Mx Reds // FC980M Silent Pink // Aula F75 Ice Veins // Rainy75 MMD Vivians
