Author Topic: Vortex Double-shot keycaps  (Read 2997 times)
Offline djellybeans
« on: Thu, 08 December 2016, 13:18:03 »
Hey Guys,
I'm using a pok3r keyboard right now and I would like to upgrade to the double-shot keycaps they offer separately. Since good keycap sets mostly aren't that available in Europe I will have to pay a decent amount just for the caps. Now I was wondering; Can the custom double-shot vortex keycaps be considered an ''upgrade'' in comparison to stock pok3r keycaps? Is it true that they produce a heavier sound? I'm really looking for keycaps that make my keyboard sound less clicky and make the keystrokes produce a heavier ''thump''
Thanks
Offline 1swt2gs
  • DOGE
Re: Vortex Double-shot keycaps
« Reply #1 on: Thu, 08 December 2016, 17:34:03 »
IIRC, Vortex PBT isn't much thicker than the pok3r caps but they ARE thicker.
Such artisan, many caps, very keyboard.
Always searching for Bro caps!
1swt2gs classifieds!
Offline davkol
  •  Post Editing Timeout
« Reply #2 on: Fri, 09 December 2016, 16:40:12 »
Umm, Pok3r caps *are* PBT and made by Vortex.
I have Poker 2 caps and two sets of PBT doubleshots, and they're the same thickness. The doubleshots only have a slightly smoother texture.
Offline buckyballs
« Reply #3 on: Sun, 11 December 2016, 21:27:44 »
If they are made of the same material isn't PBT all supposed to be a bit rough?
Offline davkol
« Reply #4 on: Mon, 12 December 2016, 06:04:06 »
No, it isn't. PBT is a material. Texture depends on the manufacturer's mold. PBT caps can be completely smooth to the point of being glossy.
