Author Topic: Kobo KBParadise V80 compatibility?  (Read 66400 times)
Offline dante
« on: Sat, 10 December 2016, 19:31:19 »
Can you confirm whether or not the KBParadise V80MTS boards will be an exact fit for the Filco Kobo frames?
If the answer is yes is there a way to run a fixed non-detachable cable on the inside?  Since the Filco's come as hardwired I assume there is some sort of strain relief?
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Moderator
  • The 00verseer of Vault 77
    • Mechanical Keyboards
Re: Kobo KBParadise V80 compatibility?
« Reply #1 on: Tue, 13 December 2016, 13:37:42 »
Certainly worth looking into...we will check this and update soon.
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline 00zeRO
  • * Moderator
« Reply #2 on: Fri, 31 March 2017, 19:27:48 »
Not an exact fit, but they can work somewhat. I don't like the fit to be honest, as the screw holes don't match up.
Offline dante
« Reply #3 on: Fri, 31 March 2017, 21:03:42 »
Thanks for looking into this and being transparent about the fit!  It's too bad KBP didn't try to mirror the market as it might help increase their appeal.
