Author Topic: [GB] Elvish PBT SA dye-sub & Laser Engraved Keycap set, Shipping  (Read 92348 times)
Offline sennin32
    • Doyu Studio
« on: Wed, 14 December 2016, 02:35:35 »
Update on Mar 9th, 2017 :
https://geekhack.org/index.php?topic=86395.msg2420092#msg2420092
https://www.facebook.com/douystudio/posts/800850810074355
Update 2017 Mar 1st :
Hi,
Every body, it's a vacation in Taiwan from Feb 25~28.
So we update later.
After few sampling.
5 side dye-sub still has some issues.
Because of the height of the cap, the color is not very even on the side of caps.
So we'll change printing manufacturer but use origin tech to print it.
We fixed the spelling issue, and I make a new file of the design.
Origin file from designer has some small align issue and hard to fix.
So I just make a new one.
There's still 5% fail rate, to solve this, our partner will personally go to factory check and pick them.
We'll pick in our studio again after printing finish.
Update 2017 Jan 16th :
Photo update : https://geekhack.org/index.php?topic=86395.msg2340051#msg2340051
As the photo shows.
Some of the keys are not well printed (off center).
And we get another sample with other color from another manufacturer.
Quality is pretty nice, and it is 5 side dye-sub, better touch feeling.
And there's a major advantage -  their model have more extras.
So, instead of pick failed caps by human, we might consider change manufacturer.
The designing is the same without any change.
But new sample has to wait till Chinese New Year ends.
We should get it with about Feb 20th.
Than we can start production after confirm.
We have some buffer on timeline at the beginning.
So every thing is still under control and no need for delay on delivery.
We will wait for the sample and make final decision on choosing  manufacturer.
Worst case is don't change manufacturer, and pick failed keys manually.
But we hope we can produce better production in the end.
Update 2017 Jan 9th :
Hi,
Really sorry to tell you that the sample got delay.
We're solving this issue with carrier now.
Will update ASAP after we get it.
And this GB will extends for few days :)
Hi, we are Doyu Studio.
Top seller on eBay
http://stores.ebay.com/doyustudio
http://shopkey.doyustudio.com/
https://www.facebook.com/douystudio/posts/721293188030118
We've ran several GBs this year
https://geekhack.org/index.php?topic=85761.0
https://geekhack.org/index.php?topic=79182.0
GB link for keycap with origin box(Higher shipping fee) : http://shopkey.doyustudio.com/021cape01grs-b.html
GB link for keycap with zip bag(Lower shipping fee) : http://shopkey.doyustudio.com/021cape01grs.html
GB link for Extra : http://shopkey.doyustudio.com/021cape01gre1.html
This GB is about a Elvish alpha keycap
Material : PBT
Profile : SA 223333(Based on Filco's)
Printing : top printed
This keycap set contain several tech of printing.
1. White caps are using dye-sub printing.
2. Green(Both light and deep) are dip-dye with white PBT caps
3. White legends on green caps are made by cutting from surface with laser, and origin plastic color shows up.
These techs make sure this cap has a nice quality and lifetime.
View more images : http://imgur.com/a/Ta0R0
This keycap set has ANSI 104 keys and some extra
Alpha set, modify set aren't get enough interesting in the IC, so we won't have it this time.
GB timeline :
Start from : 2016/12/14 00:00 (UTC+8)
Ends on : 2017/1/10 23:59 (UTC+8)
Estimate Shipping : Mid Mar to Late Mar, 2017
(2 months from GB End, We hope we can finish it within 1 month after GB ends,
But it's a little rush and Chinese New Year is from Jan/25~Feb/3, afraid we can't do it within 1 month,
So we promise a timeline which is easier to finish.)
If you have any questions/issues.
Please contact sy_yang@doyustudio.com
« Last Edit: Mon, 22 May 2017, 09:48:55 by sennin32 »
Offline sennin32
    • Doyu Studio
Re: [GB] Elvish PBT SA dye-sub & Laser Engraved Keycap set
« Reply #1 on: Thu, 15 December 2016, 16:25:50 »
Thanks for approval :)
Offline Dyaems
« Reply #2 on: Thu, 15 December 2016, 18:29:03 »
will be making a payment by next week  :thumb:
   B.face X2
  65g Zealios
Offline Jubileus
« Reply #3 on: Thu, 15 December 2016, 20:44:01 »
The second sample pictures will still be up right on Dec.20-25? I'm gonna wait for that before I buy.  :thumb:
Offline sennin32
    • Doyu Studio
« Reply #4 on: Thu, 15 December 2016, 23:55:35 »
Yes,
Sample is still processing.
Offline SpecTP
« Reply #5 on: Fri, 16 December 2016, 11:00:24 »
got my order in.
Offline trenzafeeds
  • **** off
« Reply #6 on: Fri, 16 December 2016, 11:26:44 »
will the second sample I see mentioned fix the legend alignment issues? they're pretty wacky in the images you have posted now
demik will never leave.
Unless he gets banned.
Offline sennin32
    • Doyu Studio
« Reply #7 on: Fri, 16 December 2016, 12:05:12 »
Yes, they will.
Actually, the issue you care about can't be fixed 100%.
The way to fix it is to pick those failed cap up.
Factories' yield rate is about 90%.
We might cooperate with another factory with more experience next time.
But it's because of they can make 5 side dye-sub printing with massive production, not because of yield rate.
Yield rate is pretty hard to increase.
When making the first sample, we only make 1 set.
And it's made by the plastic that is still under testing.
So it can't be picked up cause no replacement to take pictures.
And you can see some issues on the surface.
For the other issue like printing errors / plastic issues.
It will fix in next sample.
We'll take some more better pictures so that you guys can see it more clear.
And maybe we can found some more bugs together before starting massive production.
You can decide join or not after we post next sample.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #8 on: Sun, 18 December 2016, 01:21:57 »
yeah aight, i'll join in on this.  :cool:
-Dana
Offline nsmechkb
« Reply #9 on: Tue, 20 December 2016, 08:39:32 »
Sorry to bother you. Could you tell me if the top surfaces of these caps are textured or smooth, please? The pictures are very nice, but I can't tell for certain.
Thank you!
Offline sennin32
    • Doyu Studio
« Reply #10 on: Tue, 20 December 2016, 10:44:51 »
Thank you!
textured!
Offline nsmechkb
« Reply #11 on: Tue, 20 December 2016, 10:46:20 »
Excellent! Can't wait to see the next round of pictures. Thank you!
Offline sennin32
    • Doyu Studio
« Reply #12 on: Wed, 21 December 2016, 03:27:01 »
Actually I never seen any PBT cap with smooth surface.
All the mold will do the sand blast, but some are rougher and some are smoother.
Offline nsmechkb
« Reply #13 on: Wed, 21 December 2016, 07:07:08 »
I've read that the SA PBT sets Signature Plastics is putting out have a smooth finish. I may be mistaken.
Offline Slash Emperor
  • Lust for life lost, keyboards acquired.
« Reply #14 on: Wed, 21 December 2016, 07:14:11 »
SA PBT is smooth. It surprised me when I got the Ice Cap set.
Offline sennin32
    • Doyu Studio
« Reply #15 on: Thu, 22 December 2016, 06:46:16 »
Oh!!!
Then, that will be the first time I notice there has smooth PBT cap.
Offline Dyaems
« Reply #16 on: Fri, 23 December 2016, 21:46:13 »
I'm just wondering, does this GB have an MOQ? I still have not ordered a set yet, since I'm still busy working even if it is holiday season  :-[
I also saw that reverse dyesub post you made on Reddit and it would look nice if the mods are actually that, though I'm not complaining with the current price + 4 blank keys ;)
   B.face X2
  65g Zealios
Offline sennin32
    • Doyu Studio
« Reply #17 on: Fri, 23 December 2016, 22:51:52 »
Hi,
MoQ is 100 sets and extra is 30 sets.
This is the deal with factory to get this price.
I think this GB can achieve that.
Mold is different, reverse dye sub you mention is cherry profile and this is SA profile~
Offline Dyaems
« Reply #18 on: Sat, 24 December 2016, 02:27:50 »
Hi,
OH yeah that was cherry profile, i forgot. hopefully i can make a payment next week for this, and reach 100 MOQ :)
   B.face X2
  65g Zealios
Offline Cocopah
  • Lurker Extraordinaire
« Reply #19 on: Sat, 24 December 2016, 02:40:36 »
This set would look incredible with the Grinched Brobot and OG Ribbit 2.
Offline rabbitfire
« Reply #20 on: Sat, 24 December 2016, 05:28:25 »
give me an invoice  :thumb:
Offline Nos0323
« Reply #21 on: Sun, 25 December 2016, 21:04:09 »
New to this kind of stuff, especially on Geekhack.
Will these caps fit Cherry MX switches?
And what is "extra" ?
Offline sennin32
    • Doyu Studio
« Reply #22 on: Sun, 25 December 2016, 21:20:47 »
You can place order in the link :)
YES,
FIT CHERRY MX SWITCHES.
But not fit for cherry steeped capslock(the stem position is off center)
Offline nsmechkb
« Reply #23 on: Sun, 25 December 2016, 22:00:18 »
The "extra" refers to an optional set of keycaps, made up of duplicates or additional keys, so if you have a keyboard with a non-standard layout, you can cover your keyboard with the base set plus the extras kit.
So, for example, I have a Leopold FC660, which uses two 2.25u shift keys, instead of the standard layout with a 2.25u shift key on the left and a longer one on the right.  Since the base kit only has one 2.25u shift key, I'd need to order the extras pack, which includes a duplicate 2.25u key, in order to cover my FC660.
Hope that helps!
Offline Nos0323
« Reply #24 on: Mon, 26 December 2016, 01:52:12 »
Hope that helps!
That definitely clears it all up for me. I really appreciate that!!
I felt so noob x-x
Offline Nos0323
« Reply #25 on: Mon, 26 December 2016, 01:53:44 »
YES,
Ah okay, so it will fit everything except the capslock? o.O
My keyboard is a Ducky Shine 5
Offline nsmechkb
« Reply #26 on: Mon, 26 December 2016, 05:00:15 »
YES,
I think Sennin was saying that this Elvish set won't fit Cherry stepped caps lock where the stem is off-center. I think the Ducky Shine 5 has a standard layout, and the base set would exactly cover it. Hopefully someone can confirm that for us.
Offline Hako
« Reply #27 on: Mon, 26 December 2016, 15:30:46 »
Does the extras kit come with a 7u space bar? It would be weird if it came with 1.5u mods and no 7u space bar...
Offline trenzafeeds
  • **** off
« Reply #28 on: Mon, 26 December 2016, 15:40:31 »
whats up with that second sample?
Offline Liam
« Reply #29 on: Tue, 27 December 2016, 02:38:44 »
Did you get the second sample yet?
IBM Model M - Leopold 750r - Custom Numpad
Offline sennin32
    • Doyu Studio
« Reply #30 on: Tue, 27 December 2016, 18:12:38 »
YES,
Yes!
Thank you.
Cause this extra is based on the existing mold.
We can't finish the new mold before GB ends.
So no 7u space :(
Hi, second sample delayed.
We might have to wait around 2017/1/5
O_Q
Offline Liam
« Reply #31 on: Tue, 27 December 2016, 23:41:08 »
Thanks for the update. I'll wait for the 2nd sample before placing my order.
Offline sennin32
    • Doyu Studio
« Reply #32 on: Wed, 28 December 2016, 09:40:50 »
NO PROBLEM :)
Offline Komatoz
  • Click Clackity Away~
    • Komatoz Kaps
« Reply #33 on: Mon, 02 January 2017, 01:41:00 »
NO PROBLEM :)
Is second sample set to be up on time (Jan 5, 2017)?
I will be waiting for second sample to order!
Reddit: /u/Komatoz
Offline pixelpusher
« Reply #34 on: Mon, 02 January 2017, 10:17:34 »
Oh!!!
PMK Industrial (all row 3 SA in PBT) were also smooth.
Offline sennin32
    • Doyu Studio
« Reply #35 on: Mon, 02 January 2017, 11:44:46 »
NO PROBLEM :)
Hi,
They're finished.
But we'll get it after New year vacation(Jan 03).
If the shipment delay.
We'll extend the deadline.
Sorry :(
Offline Komatoz
    • Komatoz Kaps
« Reply #36 on: Mon, 02 January 2017, 17:00:42 »
NO PROBLEM :)
Hi,
They're finished.
Sorry :(
No problem!! Thank you for the updates I seriously appreciate it!!
Looking forward to the updated samples!! I really want these keycaps but I wanna make sure first haha.
Reddit: /u/Komatoz
Offline sennin32
    • Doyu Studio
« Reply #37 on: Tue, 03 January 2017, 10:52:07 »
No problem :)
Will update ASAP
Offline Liam
« Reply #38 on: Sun, 08 January 2017, 07:30:01 »
Any update so far? I believe it's the 8th already.
Offline Geckt
« Reply #39 on: Sun, 08 January 2017, 14:57:40 »
IN!
« Last Edit: Sun, 08 January 2017, 14:59:13 by Geckt »
Offline Komatoz
    • Komatoz Kaps
« Reply #40 on: Mon, 09 January 2017, 00:20:27 »
No problem :)
Will update ASAP
Any update??
Reddit: /u/Komatoz
Offline Geckt
« Reply #41 on: Mon, 09 January 2017, 04:47:49 »
No problem :)
Will update ASAP
Any update??
Yea, would like to see more samples/shots of the extras as well.
Offline trenzafeeds
  • **** off
« Reply #42 on: Mon, 09 January 2017, 05:22:12 »
The groupbuy literally ends tomorrow, and I think anyone in the right mind who looks at those initial samples would want to see proof of improvement before laying down money. Not gonna lie dissapointed we still haven't seen anything.
Offline sennin32
    • Doyu Studio
« Reply #43 on: Mon, 09 January 2017, 05:33:15 »
Hi,
Really sorry for delay.
Because of shipping issue, we haven't get second sample...
We're contacting factory and shipping carrier to solve this problem.
We'll definitely update the photo of new sample before we processing it.
And I think this GB will extend for few days :(
Offline trenzafeeds
  • **** off
« Reply #44 on: Mon, 09 January 2017, 08:09:09 »
good to hear  :thumb:
no problem that the shipping is delayed, as long as I can still buy after I see the sample!
Offline Loft
« Reply #45 on: Mon, 09 January 2017, 19:50:16 »
Holding out for that second sample.
Offline afrokobe
« Reply #46 on: Mon, 09 January 2017, 22:25:17 »
I would love to buy this, but not really a fan of green D:  Hopefully you guys will run other colors too.
Offline Unforgivable
« Reply #47 on: Wed, 11 January 2017, 09:17:02 »
« Last Edit: Sun, 13 December 2020, 16:15:28 by Unforgivable »
Offline Dyaems
« Reply #48 on: Wed, 11 January 2017, 19:28:18 »
Are we still able to join in on this, Sennin? (:
You can still join as the GB is not closed yet. People are waiting for the updated pictures.
   B.face X2
  65g Zealios
Offline Liam
« Reply #49 on: Wed, 11 January 2017, 21:24:53 »
I just realized the profile 22333 you provided isn't right. It's missing 1 row. So is it gonna be 223333?
