Author Topic: Whitening a yellowish space bar on an IBM Model M keyboard: HOW?  (Read 2845 times)
Offline devhdb
« on: Wed, 21 December 2016, 05:03:41 »
Hi,
I'm a newbie here so please don't bite me.  :cool:
I've used the Advanced Search on the forum and I'm sure that this question must have been asked before, but I've been unable to find it. :(
So, basically it's what the title says: I have used the suggested method to clean the Model M as per https://geekhack.org/index.php?topic=32995.msg623677#msg623677
Yet I have a 'rebel' space bar which, after the years has become quite yellowish and doesn't come out white enough as the rest of the keys. I wonder if it's made of a different kind of plastic...
What do you do to whiten/bleach key caps such as the space bar?
 :thumb:
« Last Edit: Wed, 21 December 2016, 05:05:14 by devhdb »
Offline hking0036
Re: Whitening a yellowish space bar on an IBM Model M keyboard: HOW?
« Reply #1 on: Wed, 21 December 2016, 10:56:18 »
All Model M Caps are PBT as far as I know, including the spacebar. ABS is usually what yellows. Regardless, you could take a shot at retrobrighting and see if that helps, but again it shouldn't really help since it's PBT, I'd just try giving it a nice scrub before going that far.
« Last Edit: Wed, 21 December 2016, 10:59:36 by hking0036 »
Realforce RF87UB 45g Uniform | Leopold FC660C w/ TMK | IBM Model M - 3/24/1997 | IBM Model F 122 - 11/25/1985 ANSI'd w/ TMK | IBM Model F XT in a box
Offline devhdb
« Reply #2 on: Wed, 21 December 2016, 14:55:02 »
Thanks por posting the link hking0036, I didn't know about that.  :thumb:
I think I can give this a try. I'm happy to hear more suggestions in case other people have been successful with spacebars following other methods.
