Author Topic: Soldering Tips?  (Read 1800 times)
Offline Harms
Soldering Tips?
« on: Tue, 27 December 2016, 19:41:36 »
Hi
This is going to be my first time building a board. What kind of tip do you use? Conical, chisel, flat, etc and is it better to have a thinner tip? Also when soldering on the LED do you cut the tall pieces before or after soldering?
Lastly, what kind of solder do you guys use and at what temp?
Thanks for any input :)
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
Re: Soldering Tips?
« Reply #1 on: Tue, 27 December 2016, 20:20:31 »
May I direct you to the Living soldering thread? ;)
|||My other keyboards :
x
Offline Harms
Re: Soldering Tips?
« Reply #2 on: Tue, 27 December 2016, 20:56:26 »
